Question about IBM ThinkPad 600X Notebook
Black Screen at boot up
Hi Scott
Can you give any advice.
I have an Old IBM Thinkpad whose batteries were completely drained.
I have recharged the main battery and replaced the CMOS battery, which has fixed the errors that I was getting about lost configuration data.
But now all I get is a Black screen with IBM and Thinkpad on it but with NO icons and NO mouse pointer.
Is this ONE DEAD PC?
**** BIrd
  • 558 Answers
May be the CMOS battery you replaced is not compatible or firmly placed.
Check if you can enter in BIOS and change setting for Power option.
Generally, F2 , ESC or DEL key used to get in BIOS.
Also you may try Tapping F8 key during startup of PC to get in Safe Mode, and then Check for Event viewer entries if any red cross entries and error found in System and Application.
For more geniune Fix to Problem, please ask to EKSE (Guru), as he is more experienced and well equipped to solve such problems.
In any case let me know the status, and do not vote till you get the solution.
Posted on Oct 31, 2008
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
My previously healthy Thinkpad T42, will not post.
The Thinkpad T42 doesn't have a reset button on it like the older IBM's used to.
There could be a problem with the battery. With the machine turned off remove AC power and then the battery. Plug in AC power again and see if the laptop will boot without the battery.
If it boots let it load up as normal and then shut it down again, reinsert the battery and try to boot it up. If it boots fine, if not then there is a problem with the battery.
Please post back if you need anymore advice.
Good luck.
Jan 14, 2010 | IBM ThinkPad T42 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Sep 23, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM thinkpad t42 boot up problem.
The most common reason is memory.
First, try to reseat (remove and reinsert).
If still a problem, test one module at a time.
Hope this helps.
Aug 17, 2009 | IBM ThinkPad T42 Notebook
Will not boot... black screen?
Try removing the battery completely and powering it up on AC power. Sometimes a dead battery (even if you're plugged in to AC) will stall a boot-up in its tracks. If this doesn't help, please reply back and let me know if anything changed.
Jul 09, 2009 | IBM ThinkPad T40 2373 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
My Battery is not working!!!!!!!!!!!!!
Discharging the battery will not harm the battery. Lenovo purposely has an annoyingly slow recharge rate because a quick recharge will shorten the life of the battery. It is not a problem if you have the patience to allow a long recharge. Otherwise spring for a second battery for quick replacement when AC power is not accessible.
May 05, 2008 | IBM ThinkPad X60 Tablet PC
IBM ThinkPad 600X Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
