Question about Sony KV-32S40 32" TV
Red timer light blinking
When we turn on the TV, via remote or manually, the red 'timer' light blinks, and we get nothing else. We wonder if we accidentally pushed a wrong button, or if we need to call someone out to look at it. My husband has a bad back, so we can't take it in, and would have to call a technician out. This is the first problem we have had with it. I believe it is approximately 6 years old.
    President:
  • 3,130 Answers
Yes you will need to call out a tech to service this for you as this set is not serviceable by the user unless they have solid state repair experience.
Posted on Sep 16, 2006
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
While watching tv I touch something on the remote to make the tv go into "on timer" The red light is blinking. I have removed power then on again the remote and tv controls work but after 4...
Check the remote carefully for a stuck button. You may have pressed a button and it went a bit crooked getting stuck.
Also, remove the batteries of the remote and try operating the TV manually. If the remote is the cause, the TV will work correctly once you remove the batteries.
Another way to check is by using a digital camera, like the one in a cell phone. Turn on the camera and point it at the remote. If you see a white light coming from the transmitter, the remote is sending a signal. Look for a stuck button.
Jan 04, 2011 | JVC AV-27920 27" TV
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
May 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KV-27S42 not on but timer flashes
The blinking light means almost 100% that the high voltage circuit has failed. Probably need a new horizontal output transistor and flyback. Perhaps an associated resistor or diode. If you have the expertise go for it, otherwise take it to a professional. In any case be extremely careful and safe. Good luck.
Jun 21, 2006 | Sony KV-27S42 27" TV
Sony KV-32S40 32" TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
