Unit powered down but won't come back on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
SOURCE: tv won't turn no the vizio logo only blinks
That problem is 2 causes,its either power supply or system board.
This are some D.I.Y procedure for troubleshooting.
Thank you and good luck.
SOURCE: I will be watching my vizio m470nv and it will
I hope you get a response. I am having the same issue. It turned off on my this morning @ 0600 and then after getting home from work I was cooking dinner and was wondering who turned the TV off. It did it again.
Then it happened about three hours after that. I wish I knew what the problem was!
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by
meg_car on Jul 08, 2009
Service by: mjsazon
