Question about Concept Slot Load Half-Din DVD Player Car Video Player
Instructions anyone know where I can get installation instructions for this unit
0 characters
1 Points
Kenwood KVT-512 subwoofer
put it in standby mode first.. then switch the rear av-out to sub.. then you can turn the sub on/off
Apr 04, 2009 | Kenwood KVT-512 Car DVD Player
hi there,
the unit wil come with instructions in diffrent laungues.
Feb 16, 2009 | Dual XDVD8181 Car Video Player
Not sure what I need for audio
Try turning your stero to 88.7. I cannot figure out how to get the sound to come out through the jacks though. I plan on buying the IR headphones at somepoint, but I would like to be able to use the jacks in the meantime
Dec 13, 2008 | Farenheit DVD-13 Car DVD Player
DNX7100 Security Code Password
While code request mode,point the remote control to the unit and enter this code 55222277or 552222777(depending the remote contro you are using)(try to press the numbers that faster you can) that is way you type KCAR from the remote control.
you will not see any change on the screen while you entering the number,only when you enter the last number the unit will go to standby mode.
if you make a mistake,reset the unit and start all over again.
let me know if works
thank you
Nov 15, 2008 | Kenwood DNX7100 Car Video Player
Jensen VM9311TS
try pressing the reset button.
Sep 07, 2008 | Jensen's VM9312 Car DVD Player
Kenwood kvt-719 brake bypass code needed
I've never seen a code that allows it, but you can do it in the wiring harness. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 15, 2008 | Phase Linear UDV9010 Car DVD Player
I have a necvox overhead unit with dvd built in I seem to have lost all audio..
Sounds like the RCA's have come unplugged between your video source and the new head unit. If possible pull it apart to check the connection of the Red and White RCA's. Good luck
May 31, 2008 | Necvox RE-8169D 8 All-In-One Motorized...
Powers on and then turns off once you try to select the options
I just finished installing my alpine iva-d300
but it says Invalid Disc
yet no disc is inside....I hear the motor inside but it won't upload or eject the cd
Nov 02, 2007 | Alpine IVA-D300 Car DVD Player
Concept Slot Load Half-Din DVD Player Car Video Player Logo
63 people viewed this question
Top Concept Car Video Players Experts
xxxxxx xxx
Are you a Concept Car Video Player Expert? Answer questions, earn points and help others
