Hi i was just wondering if you could help, i turn off my laptop last night to shut down and instal updates ,but this morning its still on logging off and its been there for some time.. is there anything that i can do to use it again? thanks
  • butterfly99 Oct 31, 2008
    Thanks ill try doing that...
Let the laptop b on battery mode
it will shutdown after some time
then restart it normally
Posted on Oct 31, 2008
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
My Toshiba is taken a long time to log off. It has not Shut down since last night
You can try shutting off your laptop manually by holding the power button down to turn it off and press it again to turn it back on.
May 01, 2011 | Computers & Internet
Hi, I have an Asus PRO50G laptop. Last night I shut it down before going to bed and assumed that it had shut down successfully, but when I awoke I found that the laptop had run itself out of battery while...
Since the battery totally ran out, hence, now you require to charge it back up kindly do not try to switch on your laptop any more unless you have left it on charger for a minimum of 8 hrs. In case even after charging for 8 hrs it is doing the same thing i.e. logging off then, press f8 key while booting up and from the selection select last good known configuration and hit enter. That will fix everything. In few cases it's also f10 button hence try both f8 and f10.
Mar 19, 2011 | ASUS Computers & Internet
My laptop doesnt start. It's not working. I was just using it last night. I was working well. I shut it down properly as I should. This morning when I turn it on. It didnt work.
Hi there, try to remove the battery, clean the terminals, then place it back, chances are the battery was dislodge. test again. hope this helps.
Aug 06, 2009 | Computers & Internet
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Acer Laptop Vista service packs 1-3
remove power supply nd battery, should allow you normal boot up.
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
