Question about Micro Innovations KB980W Keyboard
My keyboard dosen't work but the mouse does!!!!!!
My keyboard is not working at all. My mouse is working perfectly fine. I don't know what is wrong with it. If someone who knows how to fix it can write back that would be GREAT!!!!! Thanks
    President:
  • 8,637 Answers
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Posted on Jan 20, 2009
The mouse and keyboard randomly disconnected and will not connect weather not i put new batteries... the only way it connects is when i remove 1 battery and push the other one in twards the spring and the...
hi dirtfreak,
Good day!Did you check the remote USB connector?try detaching it from the port inserted and reinsert it in other USB port and see if it works.,change the batteries with new one if you have..then reconnect all..
mastergani
Feb 08, 2011 | Logitech Cordless Desktop EX110
My keyboard neither mouse are not connecting my computer it just doesnt show up i have a remote that connects to the same usb sender perfectly fine but the mouse and keyboard wont. Thank you,
its hardware problem, may be water or any liquid get inside and make the keyboard not work state, do you have any function key to disable keyboard or mouse mean go to control panel -> hardware setting check whether mouse was disable or not, if it disable mean make it enable so that your mouse works good same for keyboard.
Good luck
Dec 30, 2010 | Acer NSK8458AN Keyboard
My Logitech keyboard worked perfectly last week, but when I came back from my friend (I had my keyboard there, for the third time) it didn't work perfectly after 1 day, it started typing randomly but when...
When my logtch does that is usally is a stuck key. It can also be a low battery or the antenna is too close or too far away.
Most of the time its a stuck key. turn it upside down and knock on it like you are knocking on a door. that usually will jar the keey loose. you may be able to find the stuck key by pushing on them and see which one doesn;t pop back or feel right. Don;t try to pry it loose do the knock.
If the battery has just enough power left you can get some wired things happening but usually it just stops working.
Move the antenna so that it is about a foot away and is clear line of sigt from the keyboard to the antenna. You may want to reset or reconnect using the button on the antenna and the bottom of the keyboard.
9 out of 10 times its a stuck key.
Dec 02, 2010 | Logitech Cordless Desktop MX3200 Keyboard...
Toshiba 2000 Equium: working perfectly in Win 98 and with partitioned 6GiG drive also with XP UNTIL keyboard suddenly all wrong: no ability to use the keyboard: added a wireless keyboard and mouse with...
use a PS2 keyboard/mouse
if they work fine then there is problem with your wireless equiment keyboard/mouse having some signal interfearance from some other equipment like you mobile phone etc...
Dec 06, 2009 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
Sep 08, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
My mouse stopped working
Check the connection to the motherboard, it's under the keyboard. Occasionally these will work loose or need cleaned. Still no mouse, then try a system restore. If the doesn't do it, then it's a faulty touch pad and will need to be replaced.
Jun 20, 2008 | Toshiba Satellite P25-S5093 Notebook
Keyboard never works mouse works fine
have you tried changing the batteries? My mouse has an issue just like that when the batteries get low.
Dec 06, 2007 | Logitech Express (967407-0403)...
Re: wireless mouse and keyboard; mouse not detected
I bought the same combo from a parts house. The guy told me the mouse didn't work but didn't know why. I had the same problem. When I inspected the mouse closely, I found that the connect button on the bottom of the mouse had stuck underneath the housing...basically in the "connect position". When I freed it, the mouse worked and still works just fine. Hope this helps
May 11, 2007 | Impression Products Impression M1 Wireless...
Micro Innovations KB980W Keyboard Logo
65 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
