Anybody mind helping out? i just got this recently. whenever i press the select button to open the inbox, the phone hangs and then it restarts itself. im unable to view whats inside the inbox.
The best thing to do is use the data cable and save all your phone no's, sms's and any other data u want to save... once you have done that delete all data on phone.
switch off phone remove the battery pack and re-insert battery pack and switch on phone.. your problem should be solved.
if solved re load data on the phone memory and try and keep sim card with less data.
regards,
vinpac.
Dear Luke,
Its seems like your phone needs to be reprogram.
I suggest that you saved first all contacts and important datas in your fone before going to a service center.
Thank a lot.
hope it helps
Angelo29
thank you. it is solved. the phone program is not how i expected it to be. when they say 200 sms is the max. but the truth is it only stores up to 190. and i have to delete every single sms =( thanks for the time.
