Question about IBM Infoprint 1312 Laser Printer
Repetitive defect from toner cartridge does NOT go away with new cartridges
Low toner light came on; user bought new (genuine) cartridge and installed it; repetitive defect appeared (2 dots near left edge); user bought 2nd new cartridge and defect remained; tried original cartridge again and defect remains. Half-test proves that defect is post-toner and pre-fuser. We blocked the laser scanner path on that side of the paper and all of the text dissapears but the two dots remain. Is this a voltage issue or something?
  • 32 Answers
Have you tried vacuuming or dusting the inside of the printer?
Posted on Jul 24, 2009
Printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
My hp laserjet m1005mfp printer is not printing document while i replace its cartridge twicely so give me solution urgently
Checking the print cartridge
Image-formation defects are frequently the result of problems in the print cartridge. If the source of the defect is not immediately evident, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to make sure that the print cartridge is still operable.
? Make sure that the print cartridge is seated properly.
? Check the print cartridge to see if it has been disassembled or refilled.
? Inspect the print cartridge to see if toner is leaking through worn seals.
? Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or
and image defects.
? Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been
To redistribute the toner in the print cartridge
Before installing a new print cartridge or when the toner begins to run low, redistribute the toner by
Jul 22, 2011 | HP LaserJet M1005 Printer
Having a clicking noise problem when installing a new toner cartridge into the fax machine. Reusing the old cartridge makes the noise go away. There is nothing wrong with the new toner (we have 2 and both...
You state that you have 2 new toners and both make a noise, but the old one does not. If both the two new toners came from the same source then it is possible that the vendor has a quality control problem and manufactured several defective cartridges. It does happen. If these are not genuine Muratec toners, that makes it all the more likely because often they are remanufactured and attention was not paid to details. Is the old cartridge from the same vendor and does it bear the same brand name if it is not a genuine Muratec item? 15 years in this business tells me that if the old one is quiet and the new ones are noisy, something is wrong with the cartridges, not your machine.
May 05, 2011 | Muratec F320 Plain Paper LED Fax
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
New Samsung toner cart reads LOW
This is due to a sensor that reads the actual cartridge is defective not the actual cartridge or the cartridge is one that was refilled and thus not put back togeather the way it should have been. So its ether or a refilled cartridge or a bad sensor. Both req. repair in some sort.
Thanks for your free question, your free answer was delivered please do rate or leave some feedback.
Apr 22, 2010 | Samsung ML-2510 Laser Printer
I REPLACE THE TONER CARTRIDGE BUT ON LCD IT DISPLAY MESSAGE TONER LIFE END,OPEN FRONT COVER AND REPLACE TONER CARTRIDGE
Is this a genuine Brother replacement cartridge, if not you may find that it is not recognised by your MFC. Also worth a try is removing and reinstalling the new cartridge ensuring all protective packaging is removed. Also remove and reinstall the Drum unit as Brother actually recommend this as part of a new toner install
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Sep 26, 2009 | Brother MFC 7420 All-In-One Laser Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
IBM Infoprint 1312 Laser Printer Logo
176 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
