Question about Maytag PAV2300 Top Load Washer
Maytag Top Load Washer Won't work automatically
My wife has to manually turn the timer to the next step to get the washer to work. Do I just replace the timer?
Hey, look in the back behind the washer and make sure that the hose is clipped up high enough to stop the water from just running out at free will.
What happens is that if the hose is just running out of the back of the washer straight to the floor drain, and it's just laying on the floor, your tub never fills up with water which means your machine won't advance to the next level in its cycle.
Does this make sense? Clip the hose up toward the top of your washer in the back and you should see your washer completing its full cycles.
Posted on Nov 03, 2008
    Genius:
  • 1,122 Answers
Yes, there is no adustment on the timer,you can go to sears .com click on parts put your model number in and get your part,cross check the price at repair clinic .com,every easy to install just has one wire connect jack,let me know how you do-mike
Posted on Oct 31, 2008
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
My maytag ensignia fills with water but stops after that. if you turn the knob to the next step, it will agitate but it wont go to the next step by itself.
Hi
Thanks for using FixYa. From what you have described it seems that the Timer(part#7 in the picture) has gone bad and needs to be replaced.
Also, check the Timer knob and if you hear a clicking sound then its certain that you need to replace the Timer as everything else seems to be working fine. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 13, 2010 | Maytag Ensignia MAV3757AWW Top Load Washer
MY MAYTAG ATLANTIS WASHER KEEPS WASHING RIGHT THROUGH THE RINSE AND SPIN CYCLES. I HAVE TO MANUALLY TURN IT TO GET IT TO START DOING THE RIGHT THING.
Hi, your timer motor not working,(burnt) or could be mechanical fault in timer, but first replace timer motor, check for timer motor, give appliances store model & serial no. for washer, and let me know when you get it, i will guide you, to install it, yes you can, it's not that complicated. don't forget asked for timer motor. good luck.
Aug 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Maytag Top Load Washer MAV6000
in the console behind the knob is the timer. there are several contacts inside the timer that tell it what to do. one of thoughs contacts is bad. you need to replace the timer to fix the problem
Nov 25, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
