Hitachi 50UX58B 50 in. Rear Projection Television
Problem for Hitachi 50UX58B 50 in. Rear Projection Television
Hitachi 50UX58B won't turn on
By smgunning on Sep 16, 2006
When the above TV is plugged into the STB from a switched outlet and the STB is turned on, the red light on the front of the TV comes on, but then goes off slowly (a few seconds) like a capacitor is discharging.
When the TV is plugged into the wall outlet, I can't even get the red light to come on at all either manually or with the remote. Its like the TV is dead.
Any clues where to start? Where can I find schematics? Thanks in advance
Solution #1
posted on Nov 12, 2006
Not Rated)
jd5449
Rank: Guide
Rating: 0%, 0 votes
try checking c707 you have to look close they go bad look around it i had the same problem a small pin hole burn in it
Was this helpful?
Yes
No
Popular Solutions for Hitachi 50UX58B 50 in. Rear
Questions and Unsolved Problems for Hitachi 50UX58B 50 in. Rear
Do you recommend Hitachi 50UX58B 50 in. Rear Projection Television?
Answer
Answer
screen has a double image. looks like the green gun is bowed at the top and bottem of the screen.... (More)
Answer
50ux58b had lost poewr, red light went out never came back on
Answer
The tv turns on for a couple seconds then turns off and a red light inside the tv blinks
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 50UX58B 50 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
