Question about Lexmark X1150 All-In-One InkJet Printer
Ink cartridge has stalled
It was printing fine when there was a loud bang and a message came up printer cartridge has stalled I opened the lid and saw a thin strip of film number j3300xa was loose please can you help? THANKS
where i can buy printer lexmark model Z640 i look on Ebay and local store but no one carry them.
Thanks
Posted on Jul 29, 2009
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    I have replaced the color cartridge and now the printer does not recognize color. Can you please help me on this?
    Hello
    Turn on the printer and check the LCD screen for messages. If your printer isn't recognizing what you know to be a new cartridge, the "Low Ink" warning will still be on the screen. Press the green "OK" button for now--if you want the message to reset later, just open and close the lid.
    Try printing a test page. Sometimes the ink cartridge simply has a faulty chip and the printer cannot recognize the ink levels.
    Open the lid via the handle under the copying tray and remove the ink cartridge in question. Check the bottom for the plastic tab. This tab must be removed or the printer cannot recognize the cartridge. Sometimes when the tab is pulled off, a small strip remains, and this can interfere with printing. Hold it in good lighting and use your fingernails or a knife to gently pry off any remaining bits of the plastic tab. Replace the cartridge, close the lid, and print a test page.
    Call the store or website customer service where you bought the ink if the above steps do not work Tell them what you tried, the exact error message your printer is giving you, and when you bought the ink. If it's within 30 days of purchase, they probably have a return or exchange program.
    Oct 04, 2010 | Lexmark Office Equipment & Supplies
    After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
    Try this procedure:
    1. Open printer lid so cartridges move to center of carriage.
    2. Lift clamp and remove black or color cartridge from the holder.
    3. Place cartridge on table with copper contact strip facing you.
    4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
    5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
    6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
    7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
    8. Open lid again, remove cartridge, remove tape.
    9. Reinstall cartridge and close lid.
    Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
    I hope this helps, if so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
    "Print carrier stall"?
    Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
    Figure 1: Open Ink Cartridge Lids
    Reseat the Ink Cartridges and Make Sure the Lids Are in Place
    1. Make sure the printer is turned on.
    2. Lift the printer's front cover.
      new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
    1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
    2. Remove the cartridges.
    3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
    4. Replace the cartridges.
    5. Snap the lids closed.
    6. Close the printer's front cover.
    7. When prompted on the printer's LCD to choose New or Old, choose Old.
    8. Press Select.
    new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
    Back to Top
    » Reposition the Encoder Strip
    1. Remove the power cord from the printer.
    2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
      Figure 1: Inkjet Printer Encoder Strip
    6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the scanner lid.
    9. Re-connect the power cord to the printer.
    Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
    The printer doesn't recognize the new original HP color cartridge
    There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
    Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Carrier stall.
    There could be 4 possibilities.
    1. Ink cartridges lids are open which is not allowing cartridges to move freely.
    2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
    3. Encoder strip is Dirty.
    4. Encoder strip is Out of position.
    Solution:
    1. Open the front cover and check if ink cartridges lids are properly snapped in.
    2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
    Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
    3. Cleaning the encoder strip:
    a. printer should be off and disconnected from power.
    b. open the front cover.
    c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
    d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
    e. Close the printer and try again to print.
    4. Repositioning the Encoder strip.
    a. Remove the power cord from the printer.
    b. Open the front cover.
    c. Gently slide the ink cartridge carrier to the middle of the printer.
    d. Gently move the top part of the printer belt to the right.
    e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    h. Once the encoder strip has been re-seated, close the scanner lid.
    i. Re-connect the power cord to the printer and try again to print.
    Incorrect position of encoder strip
    Correct position of Encoder strip
    Hope it should fix the issue.
    Nov 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Hardware Error 0502
    Solution:
    Sep 20, 2008 | Dell A940 All-In-One InkJet Printer
    Cartridge stall message
    Solution:
    Apr 07, 2008 | Dell 922 All-In-One InkJet Printer
    Error 1200, printer carrier stall
    check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
    Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
    Cartridge stall
    Solution:
    Sep 04, 2007 | Dell 924 All-in-One InkJet Printer
    Lexmark X1150 All-In-One InkJet Printer Logo
    296 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
