Set the D Recovery as Active
I can't seem to find instructions anywhere on how to set the D partition recovery as active so I can reinstall my windows
  • metal_923 Oct 31, 2008
    its a HP Pavilion 1312n Desktop and the partition is D: I had a backup of it the whole system on an external but I used a windows xp home version and it doesn't seem to have the backup utility so I can't back up from the external
  • dcomputerman May 11, 2010
    What is your system and what's the software on the recovery partition?
    Scholar:
  • 89 Answers
Missing Operating System on D: partition Bootup
Follow the steps from this site http://www.wikihow.com/Change-the-Active-Partition-of-Your-Hard-Disk-with-Parted-Magic. When you changed the active partition you told the computer to look for information from the wrong partition. Using the program from that site will allow you to make the other partition active again. You'll then be able to boot into Windows again. As far as making backup discs, I believe you hit F11 while booting to access the recovery partition. From there you can make your recovery discs. Not 100 percent sure on that though. And you will need to get the windows partition set back as active first.
Jun 19, 2013 | HP ProBook 4510s FM849UT Notebook
What should i do if recovery partitaion delet from my laptop
Try Active@ Partition Recovery. I've used their boot disc software before. It easy to use.
http://www.partition-recovery.com/
Oct 06, 2012 | Lenovo G580 Laptop
How do i reset fujitsu esprimo back to factory settings its on vista
Hi!
You can press 'F11? key during the startup process to reach a recovery screen, you just need to select 'Restore to factory settings' and it automatically formats the hard drive and the image file from the recovery partition is extracted to the active partition and Operating system is reinstalled .
Hope this can help. Take care.
Jul 21, 2011 | Samsung Computers & Internet
Need a recovery cd
Hello HP do have a built in recovery option, restart the computer and press F11, if not and you can get onto your computer go to:
Start - Run - type compmgmt.msc then type enter
then disk management
find the recovery partition it should be seperate from C:
mark the recovery partition as active
then restart and press F11
if it still does not work you you can always go to this link:
http://www.best2serve.com/page/rcd_landing/gbr/eng?gclid=CIuJhcGYhqoCFUoc4QodDhYzzw
or you can just reinstall windows but make sure you download the drivers for your computer.
Jul 16, 2011 | HP Compaq Presario SR1910NX (EX310AA) PC...
I have a acer AL5100-ud4400a i pressed alt+f10 while booting now im stuck on (verifing dmi pool data...... update success) nothing else happens any answers would be appreciated.
Huh, it seems to be stuck picking a boot device. Narrow it down by removing (disconnecting) USB, flash or optical devices, and see what happens. It might have been polling a failed DVD-ROM drive or something....
You can also try reseating your videocard or installing a lesser one until you get it booted....
Feb 14, 2010 | Acer Aspire L5100 Refurbished Desktop PC -...
RecoveryDisk Creator does not offer any disk selections to create
To access the recovery partition you need to boot up on a DVD with a partition manager on it, then set the hidden partition as "ACTIVE" and un-Active, the existing partition, then remove DVD and reboot, then the laptop will boot from the recovery partition and should autorun start the recovery procedure.
Jan 28, 2010 | Toshiba NB205-N311/W Netbook
How do I do a hard drive recovery on a toshiba equium m50-244
You can recover your full hard drive using a secondary hard drive which has an OS installed by "Active File recovery" or perform a partition recovery using "Active Partition Recovery" both of their trial version can be downloaded from the net.
Dec 31, 2009 | Computers & Internet
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
I need to restore to factory settings
If thats the case then you have no choice but to get an actual Operating system ce and do it form scratch.
Dec 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
System recovery
Yes. Using the cds supplied by dell, boot the operating system cd. Delete the active partitions, then quick format it and proceed to reinstall windows. Once windows is installed, use the supplied application and driver cd to reinstall the applications and drivers that came originally with your computer, again following the onscreen instructions.
Jun 30, 2008 | Dell Inspiron 2200 PC Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
