Question about HP Pavilion dv6000z Notebook
HP Notebook not powering up
My HP notebook every once in awhile will not power up. The AC adaptor is receiving power, but when you push the "on" button, it does not power up. I received some guidance in the past to unplug the power source, remove the battery, and then hold down the "on" button for several moments which I understand drains residual power from the system, and may correct many problems. I then connected the AC adapter to a wall outlet and plugged the other end into the computer. This worked! Note: this did NOT work when the computer was plugged into the surge protector. Why the difference?
I don't want to keep doing this each time. Does someone know what could be the problem? I didn't want to remove and reseat the RAM if I dont have to.
  • 1 more comment
  • aprelmr Nov 04, 2008
    Occasionally my screen will blink (like that of the televisions in the movie Independence day) then...powers off. When I try to turn it Back on it will act as if it's going to power up, but never get past the power light. The screen will glow...black, and then it all shuts off again. Some times the power lights stay on and sometimes immediately back off again. As long as I let it drain completely and power up after doing so, it works again......help? Hp Pavilion Ent. PC, only a year old. Also, when having this problem the light on the left side by the SD/etc. card slot lights up and seems to be a part of the problem.
  • Anonymous Nov 05, 2008
    None of this works for me but i have the same problem
  • Anonymous Jan 23, 2009
    Same my comp was working then wouldnt turn on. The unplug, remove battery, and hold down power butto nthing worked though thanks!! Now I have to see if I can put the battery back in without it messing up again :p
  • 186 Answers
First, try powering the Notebook by pressing the Quickplay button as if the issue is with the Power Button, it should start.
You need to get the Power Button of the Notebook repaired if the Notebook starts by pressing the QuickPlay button.
However, if the issue is different and the notebook doesnot start by pressing the Quickplay button, I recommend you to try removing the RAM of the Notebook and try with One RAM stick at a time to boot the Notebook and also by checking the Memory sticks in both the Memory Slots.
You can find the required instructions to remove and replace the RAM modules in the Notebook from the Manual of the Notebook which is available through the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructions starting from page number 104 of 233 in the Manual.
However, if the issue persists, it can be a Hardware issue for which you may have to get it repaired.
Additionally, I would like to inform you that HP had identified some hardware issues with few Notebooks installed with AMD Processors and is providing free repairs for notebooks purchased and currently available in US and Canada.
You need to get the Product Number of the Notebook which is indicated with P/N and is printed on a white sticker pasted at the bottom of the Notebook.
Check if the Product Number of your Notebook is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If your Notebook product Number is listed in the link provided above and if the Notebook is installed with AMD Processor, you need to contact HP Chat Support and provide the required details and get the Notebook repaired by HP for free.
You can find more information about this repair offered by HP from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You can contact HP Chat Support for DV6000 Notebooks preinstalled with AMD Processor by clicking on this Link.
Hope this helps...
Posted on Nov 11, 2008
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Used my 6910 with battery power. It evetually dies. When I got home I plugged it in and it won't turn on. Took the battery out and it still won't turn on. Get green lighting bolt but won't power up. Help
Disconnect the AC adaptor and remove the battery pack from the computer, then press and hold the power button for 30 seconds.
Second, remove the RAM module, clean the slots then reseat it.
Now, turn on the Computer by connecting the AC adaptor and with the battery out of the Computer.
Nov 20, 2009 | HP Compaq 6910p Notebook PC PC Notebook
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Will not power up with ac adaptor or with battery, does not show charge light when hooked to ac has 18.3 vdc on laptop end of ac adaptor
The Power cable might have gone bad but if changing the power cable doesnot resolve the problem then surely motherboard has gone bad.
Oct 11, 2009 | HP Pavilion dv4217cl PM 740 1.73 GHz 1GB...
I have a hp dv2000 thats not turning on the power light comes on
Disconnect the ac adaptor and battery and then press and hold down the power button for 30 sec, and the relese it and connect the ac adaptor and battery and try 2 turn on the NB
Sep 14, 2009 | HP Pavilion dv2000t Notebook
Does not start; no power indicator light
Take out the battery and then try the different ac adaptors. If you still get no lights on the laptop then the motherboard is bad and would need to be replaced. Just make sure that you know at least one of your ac adaptors are good.
If the adaptors have lights and they turn on then you know the ac adaptor your working with is good. Also make sure they are plugged into a good working outlet.
May 29, 2009 | HP Pavilion ze2000 Notebook
Message that battery needs replacing last week but it was still going
Remove the battery and ac adaptor. also remove any peripherals.
Make sure that ac adaptor is working ok
Then press power button and hold that for 20 seconds to statically discharge the notebook. Then plugge that into the mains (without battery) and try to turn on. IF Notebook will not boot. Call service as mainbord needs to be replaced.
May 27, 2009 | HP Pavilion dv9000z Notebook
Hi. My HP nx7000 Notebook does not switch on at all
If you have warranty get it in for a new m/board ok
May 07, 2009 | HP Compaq Business nx7000 Notebook
No power to lap top
make sure the other side of the adaptor is also pushed in fully...i hope this can help
Dec 23, 2008 | HP Compaq Business Notebook NX9005...
Please Help
There might be problem with your power adaptor.
You can check with your adaptor.
Next is ? Is power showing on AC leds....or not???
you can chk by changing your adaptor.
Apr 24, 2008 | Acer Aspire 5520-5908 Notebook
HP Pavilion dv6000z Notebook Logo
508 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
