Question about Samsung DynaFlat TX-P3064W 30" TV
TV doesn't turn on
Hello I was washing TV and suddenly It came a big noise and many crashers in the screen I turned off the TV and waited for 20 min. I tried to turn it on again, but it didn't, just a little noise, like a test program Can you help me please??? Thank you
  • 1 more comment
  • Maurizio Guerrero Sep 16, 2006
    what a smart solution.........don't let me waist my time with your stupid comment
    my daughter wrote what I said about you comment, I didn't check what she wrote. "sorry"
    it's WATCHING,like she wrote before, the Tv just started with a noise and red screen. I turned off, when I turned on again nothing happen, just noise
  • pink guitar Mar 09, 2008
    The tv will not turn on. Seems like a relay or switch refuses to work
    President:
  • 3,130 Answers
Washing TV where in a bathtub.. Oh man Tvs cant be washed in a sink or a bathtub.??
Posted on Sep 16, 2006
  • Larry  Dillon
    Larry Dillon Sep 16, 2006
    Ok man I see you have no sense of humor, Please explain what you were doing when the set went out? you say washing? Washing WHAT? The screen the cabinet? We cannot look into a crystal ball and give you a solution if you do not supply all the info.
  • Larry  Dillon
    Oh OK watching TV LOL that explains it. Ok Lets start over then.
    If it turned a red color and went pop three things could be wrong. It could have been the picture tube shorted and blew out the sweep power supply, The drive circuit for the picture tube shorted out, Or the flyback transformer shorted out ,popped and took out the sweep supply as well. This is a set thats not made to be serviced by the consumer. Im sorry to say that it will probably not be worth repairing unless you have any solid state electronics repair experience. Thats the way this world is today. A throwaway, landfill dumping place. I see it every day. if you want to invest into an estimate. You could maybe get lucky? Its up to you now as a 32" RCA at wally world is only about 220 to 250 now a days. Good Luck
Ps3 slim turns off without showing any yellow light, it´s brand new and it doesn´t show any image on the tv screen, it takes like 20 seconds after turning it on for it to shut itself, and then...
FIRST IF U HAVE 2 HIT ANY EQUIPMENT THAT SONY MADE ITS NOT GUNNA WORK RIGHT PERIOD MANLY B/C SONY SUCH A BIG COMPANY (YES THEY MAKE OOPSIES) AND DONT MAKE SMALL ERRORS LIKE THAT ALL IM SAYIN IS BUY A NEW ONE IT GOT MEST UP IN BUILDING PROCESS OR U ACCDENTLY DROPPED IT OR SOMTHIN HOPE I HELPED
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
I have an RCA 52" screen TV and I was watching tv and all of a sudden the picture went blank and then the TV shut off. When I try to turn the tv on all i get is a scratching noise and then it turn off. can...
Hello again you need to Rate my solution other wise they are not going to pay me! since i did give you correct answer to fixing your TV ThanK You Replace 3 capacitors cp150 2200uf use 25v and cp114 cp120 220uf 35v.
Dec 19, 2009 | RCA HD52W58 52" TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Tv doesn`t start
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. The board on left, you will see the cap tops are swollen.
Thanks for using FIXYA, BIG IRISH.
Jun 03, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Tv turned off and started beeping noise
Sound like high voltage splitter ( born or defected ) Am sure this is your problem. Or maybe fly back defected. Check for possible loose connections. Thank you !!
Jul 20, 2008 | RCA P52926 52" Rear Projection Television
Phillips 42" flat screen ty
Well, I spent $20 on FixYa which did absolutely nothing and now and waiting for the Phillips to show up to take my TV to their shop (which alone will cost me $100 in itself) and wait for approximately 2 weeks to find out if the fix costs more than the TV is worth, in which case, I'll be out thousands of dollars, plus $20 to you, plus the Phillips charges AND whatever a replacement TV costs.
Did that answer your question?
May 19, 2008 | Philips Televison & Video
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Nov 02, 2007 | Insignia IS 20" TV040919 TV
Samsung DynaFlat TX-P3064W 30" TV Logo
101 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
