Question about Microsoft Windows XP Home Edition
Boot loader problem
I ' ve done dual booting but can' t see boot loader for os selection only grub> appear help me please.
  • shaileshg_9 Nov 01, 2008
    Thanx!!!!!!!!!!
    Sksree406!!!........................:)
    Suggestion really helpful !!!!!1
  • Frank
    Frank May 11, 2010
    do you have the multi-boot menu setup???
  • 61 Answers
I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.
Posted on Nov 01, 2008
  • rsbrn Nov 27, 2010
    ""I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.""
    OK, my problem is HOW TO REINSTALL ? WITH A LIVE CD ??
Have a dual boot system, windows7 & linux. tried to update to windows 10. stuck at grub rescue.
It sounds like grub can't find the correct partition to boot Windows 10. This should get you through it: http://askubuntu.com/questions/654386/windows-10-upgrade-lead-into-grub-rescue
Keep in mind that Microsoft never tested the upgrade on a system that dual boots with Linux and uses the Grub loader. You are in uncharted waters.
Dec 24, 2015 | Computers & Internet
Can't factory restore with dual boot system.
I run Windows 7 and also sometimes Fedora 16, Backtrack 5 and Ubuntu. Problem with reinstalling windows is it will write over the GRUB loader and you wont have linux there anymore. You are meant to have Windows first then install linux afterwards so you have the option of both.
Backup any files that you need and reinstall Windows then reinstall Linux. Its too much effort and mucking around to do it the other way even though it can be done
Oct 21, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
Am pulling my hair out. I'm a newbie to Linux but keen to get into it. Installed 9.10 as a dual boot alongside XP and after problems with grub, which I have re-mounted, I get to the OS choice page. XP...
Backup, Repairing and Reinstalling GRUB
  • To make a backup a copy of the existing menu.lst file use: cp /boot/grub/menu.lst /boot/grub/menu.lst.oldYou can try re-installing the grub using the Ubuntu Live CD, in two different ways.
GUI
  1. Boot your computer up with Ubuntu CD
  2. Go through all the process until you reach "[!!!] Disk Partition"
  3. Select Manual Partition
  4. Mount your appropriate linux partions / /boot swap .....
  5. DO NOT FORMAT THEM.
  6. Finish the manual partition
  7. Say "Yes" when it asks you to save the changes
  8. It will give you errors saying that "the system couldn't install ....." after that
  9. Ignore them, keep select "continue" until you get back to the Ubuntu installation menu
  10. Jump to "Install Grub ...."
  11. Once it is finished, just restart your computer
Jul 27, 2010 | Canonical Ltd. Ubuntu
Boot loader for fedora8 & windowsxp
Boot a Linux Rescue Disk and Re-Install Grub with the command. "grub-install"
mount /dev/your_boot_partiton /boot
grub-install --root-directory /boot /dev/hda
The Boot Sector is Stored on the first 512 Bytes of the physical Disk.
Sep 23, 2009 | fedora Linux Operating System
My computer won't boot to second operating system.I have 2 OS and can't select the one I want to boot to. Please help..
Most OS require that as you install them you select how / where you install.
If you selected the same directory as your first installation then you will not be given an OS boot option.
For dual OS it is normal to select a second drive as the location.
If you had two OS before and they were working fine then you may have corrupted the boot loader in some way.
Knowing which two OS's you have may have been useful as Linux brings new challenges to the table.
Sep 06, 2009 | Microsoft Computers & Internet
No grub loader
You havn't mentioned whether Ubantu inquired about the grub settings during its installation or not. If Windows doesn't have the boot loader than you can manually check it by looking at the boot flag set at a particular partition. This can be done by using an open source media GParted live cd, which can be used by booting from your CD Drive and then you can check and also set the boot flags at a particular partition. You can find it here: LiveCD-Download-8864.html">http://linux.softpedia.com/progDownload/GParted-LiveCD-Download-8864.html After burning, boot from it and in the GParted menu set the boot flag for the Ubantu partition, then you can use your your Ubantu, only if installed correctly, may be you can't use windows at that time, then remove the boot flag and windows will be back. Try installing Ubantu again and check the settings for grub bootloader.
Aug 20, 2009 | Computers & Internet
Boot Loder Problem when working with two operating System
best practice it when installing windows and linux install windows first and then linux. GRUB or LILO boot loader is much better then windows boot loader and very easy to reinstall. Mandriva cd should have a rescure feature that will allow you to reinstall the boot loader.
Jan 15, 2009 | Computers & Internet
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Dec 06, 2008 | fedora Linux Operating System
Ubuntu Repair Grub
Do you have any other OS's installed? Its with the Grub. mostly looking for another OS. let me know.
Aug 06, 2008 | Canonical Ltd. Ubuntu
Where is Linux mbr file
There's nothing like the Linux MBR File. The option to boot to multiple operating systems is controlled by a software called as the "Boot-Loader".
Windows XP and Linux both have their versions of boot-loaders. The Bootloader that Windows XP uses is called the NTLDR, whereas Linux provides many bootloaders (prominent among them being "Grub" and "LILO").
>but Linux is shown in the manage option from the My Computer in Win XP 2.....
That is the control section of NTLDR. So from what I understand you shouldn't have a problem selecting the operating systems.
If you want the Linux bootloader taking control of the boot process, you can always install it.
All you need is a Linux CD and then run the setup for "Grub" or "LILO".
Information about installing Grub or LILO can be found easily on the internet.
Oct 19, 2007 | HP Data Protector Express Software...
Microsoft Windows XP Home Edition Logo
188 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
