Question about O2 Xda II mini
No network I can't connect to my network. I did try using other SIM cards but the problem is still there. Tried a soft and hard reset serveral times. No go. I also tried tinkering with the phone settings. Did try the manual and automatic setting for the network. Still won't work. Help. Thank you guys very much.
  • sunkara_nave Nov 07, 2008
    i some times dont get the network of the service provider(airtel),where as the other mobiles will get the full signal strength in the same place.even i have done all the the things like reseting and changing the sim cards but .i think it the the problem with the phone anteena.do suggest a solution for this.how can i increase the sensitivity og the anteena.thanks & Regards-Naveen
  • prithvi_chau Mar 07, 2009
    i am not gettng connected to the network...i've checked all the
    settings and tried changing the sims also but still it shows no gsm
    ....plz guys help me out plz.....thanks
  • 24 Answers
Get antena coil changed
Posted on Dec 20, 2008
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Feb 02, 2015 | Kyocera Cell Phones
My blacberry 8520 reflects a red sos on the screen. I have changed my sim card, try a soft and hard reset, turned wi fi and bluetooth connection off but still, the problem persist
Make sure the metal bracket that holds the sim card in is secure and check it for damage. Since you've already changed out the card and have tried resetting the phone, check the sim card contacts on the phone. If they are wearing out, that could cause the problem you are having.
Sep 19, 2013 | RIM Computers & Internet
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even...
My Xda Zinc displays no network service all the time. I already tried changing sims but none of them has network signal. i tried the soft and hard resets but still doesnt work. I cannot call, txt and even received messages. need your advise. pls. help.
Nov 06, 2009 | O2 Xda Zinc Cellular Phone
Steps to hard reset
For the hard reset on the phone, you need to take off the battery of the phone then remove the sim card. After that place the battery back without the sim, please enter *2767*3855#. Just a reminder everything will be deleted on the phone, it will restore back to the factory settings. If this procedure would not help the phone needs a reflash.
Jul 09, 2009 | Samsung SGH-a737 Cellular Phone
No Service for my etisalat card alone
try others sims i mean others one or other network sims
Jul 08, 2009 | i-mate Jama 101 Smartphone
Reset G1
Hi, I had that problem. I first verified that my TMobile internet was activated on my account and on my SIM card by putting the card in another phone and connecting to the 'net on it. Then I found the APN setting on the G1 and I changed the APN at the heading "T-Mobile US" from the new 3G APN "epc.tmobile.com" to the older APN "internet2.voicestream.com". The APNs can be accessed on your still-locked phone by pushing the "Menu" button at the sign-in screen. Scroll down to "T-Mobile US", select it and change "epc.tmobile.com" to "internet2.voicestream.com", exit by pushing the left-arrow button a few times, then re-enter your GMail info. If the "Edge" icon has appeared in the menu bar area, then you're golden!
Nov 17, 2008 | HTC G1
Phone keeps rebooting
is the button near the reset hole? possibly the button is somehow pressing the reset switch, possibly stuck somehow. Other than that try a hard reset, instructions below.
Soft Reset
Put your stylus in the hole in the lower left corner where it says “Reset” Soft Reset will reboot your device just like when you reboot your PC. No data will be lost, under normal circumstances that is.
Hard Reset
Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
Oct 15, 2008 | Siemens SX66
Esn is not on treo 600 w/ cam
My ESN was also missing from my treo until i switched on the wireless. try it.., let it load the network then look for the ESN. note my network did not have a sim card. you may need to put in a sim card if your treo network requires it then check. good luck.
Sep 01, 2007 | Palm Treo 600 Handheld
Phone will not connect to network
hi i was also having the same problem but i installed radio version 1.13 for my mini and the problem is somewhat solved though not completely
Aug 01, 2006 | O2 Xda II mini
Computers & Internet Logo
83 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
