Question about Samsung CXD2512 25 in. Combo
TV shuts off after 10 sec
TV shuts off when VCR tries to eject cassette shuts off after 10 to 20 seconds. We tried many things but after using a flashlight to look inside it stayed on for a while. Now we use little christmaslights at the open VCR opening and the TV stayes on.But I cannot use the VCR with the open front. There must be another solution even if it works fine. A little bulb maybe, but where??????????And how to install???
  • rick59 Nov 16, 2007
    Is the any wat to unhook the vcr and still use the tv?
    Sergeant:
  • 337 Answers
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Posted on Sep 19, 2006
My HV-MX1U is definitely over 14 years old and was one of the best electronic devices I ever bought. Nothing was ever replaced or fixed in it so, obviously whatever parts like belts or etc need to be...
Probably both. There is a mode or position switch that tells the processor what position the deck is in. If that has failed that could be a cause also 14 years for belts is a very long time. You may find a kit on fleabay but switch wise, I doubt it.
Mar 24, 2017 | Aiwa HV-MX1 VHS VCR
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Power shut off
The set is still sensin a problem thats why it shuts off, in this units the problem is in the vcr section,check the cassette assambly sometimes is jammed and it will not load or one side of the cassette tray is pushed in too far or misaligned.It will continuo to shutdown until the problem is corrected.Be careful when working on it.
Oct 01, 2006 | Symphonic SC313D 13 in. TV/VCR Combo
Samsung vr3607 vcr is locked
following is pasted from SV-7000W manual: 1 To lock the VCR, hold down the P/STILL (II) button for approximately five seconds. Result: The lock indicator (LOCK) is displayed. If a cassette is in the VCR when you lock it, the cassette will first be ejected. 2 To unlock the VCR, hold down the P/STILL (II) button again for approximately five seconds. Result: The lock indicator (LOCK) is no longer displayed. If that fails, try the same thing using the play/stop button. Cheers
Nov 13, 2005 | Samsung VR3607 VHS VCR
Samsung CXD2512 25 in. Combo Logo
341 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
