Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchen Aid Superbra Freezer Settings model ksrs25qf00
I need to freeze veggies at O derees. What of the four setting 1-4 would equal zero degrees? What number should I set the freezer to be at zero degrees? Email me at cdunlap@wilkinsonandassociates.com
    Genius:
  • 1,122 Answers
21/2,will give you 0 to 8 degrees,the hiher you set the dial the cooler it gets in the freezer-mike
Posted on Oct 31, 2008
I have a kitchen aid KSC24C8EYY the problem is that the refrigerator does not cool stay cool below 40 degrees, Holding 43-45 range. The freezer maintains freezing but not to the 2 degree setting.
well, how full is your fridge. if your fridge is blocking any of the return air vents, thats usually where the problem lies with side by sides. you need good air flow in these models for proper temps in the fresh food compartment
Dec 18, 2016 | Refrigerators
What settings do you recommend for the refrigerator and freezer/
fridge --around 4 ( should be at 5 degrees c and freezer around 6---minus 20 degrees c
for the fridge settings the numbers work down from hot --7 to zero --- 1 where as the freezer works from 1--- zero to minus to 7 really cold at -20
adjust each depending on the time the door is open and the frequency of the opening ---examples
if you find that lettuce is freezing at 4 and you are the only person using the door , put it up to 5 but if there a family and the door is continually being opened or held open while the minds are being made up , you may have to consider 2 or 3
Sep 18, 2016 | Amana Side-By-Side Refrigerator 26 cu. ft....
My baking is set on celcius instead of farenheit.
sorry i dont know how to switch it for you but i do know how to convert c to f
Degrees c times 1.8 plus 32 equals f temp
Example 100c is boiling point so 100 times 1.8 equals 180 add 32 to that equals 212
zero degrees c is freezing point
zero times 1.8 is 0 plus 32 is 32
200 times 1.8 is 360 plus 32 is 392 ect ect ect
Jul 22, 2011 | Whirlpool Kitchen Ranges
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kitchen aid superbra electric double
replace the left & right hinges ( if stainless door they have stronger hinges for this.. this is a very comm problem .. in some model you can use shim kit for this problem but replacing hinges is best avenue . mm
Dec 03, 2009 | Dryers
Frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
May 20, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Kitchen aid refrigerator freezing in refrigerator
Could you look inside the door near bottom outside frame of fresh food side and get the model numbers for me to assist you better. Also if you have a way to check the temperature as you change settings on the thermostat for the fresh food section. We need to see how the thermostat responds to changes in settings. If no changes then we need to focus on the thermostat. Also there is duct that comes from freezer that can have a damper opened or close to different settings. Let me know the model and I will pull up the drawings for your model. Thanks Sea Breeze
Mar 20, 2009 | KitchenAid Refrigerators
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
78 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
