My cd-dvd drive not working - Computers & Internet
  • dcomputerman May 11, 2010
    What's your system (motherboard/brand, etc) and what's the drive?
  • 90 Answers
Is it not ejecting? Or it is not reading any CD at all?
If it is blinking but not ejecting then try a Paperpin, insert it gently into the Hole present just at side of Flashing light, it will eject out
Otherwise, slap it gently over the top of CPU Cabinet, it will open out.
If it is not reading CD at all, then check the entries in Dev. Manager for CD Drive and let me know.
Note: Dont Vote Till you reach to some definite solution.
Posted on Nov 01, 2008
Cd dvd drive not working
>> try to check with other cd's or dvd's
>> if not working go to device manager and reinstall dvd drivers
>> still if you persist with problem n you know about hardware try to replace with other dvdrom
>> last but the best let allow to visit hardware technician..
Dec 17, 2012 | HEWLETT-PACKARD 620 XT964UT Notebook PC
My DVD drive D works fine. Problem is with one particular CD.
this is a very common problem for all CD/DVD drives... sometimes.. there are CD-R DvD-R brands that will not work with your CD/DVD drive... its compatibility issues... another possibility is that the CD burning was bad.
Jul 03, 2009 | Memorex (32025638) (25 Pack) 16x DVD-R...
Dvd and cd burner problems
why can't i burn a dvd or cd on my used dvd rewritable drive the destination drive won't show my dvd burner?
Mar 17, 2009 | Philips Phillips 16X External DVD 2XRW...
DVD/CD DRIVE NOT WORKING
Check the cables if they are connected properly and see if the cd/dvd rom is first detected in bios..
Jan 28, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Both drives not recognising disks
Have an LG Super Multi DVD Drive, Model:GSA-4120B.
Won't recognize any disk, CD or DVD and won't play any audio video
Device manager says, it's working properly
Dec 28, 2007 | LG (GDR8164B) Internal DVD Drive
Boot error, won't even boot with xp cd
hi.
you might wanna check if your XP is a dvd or cd. if it is a dvd your cd drive can not read dvd cd's. if it is a cd than your cd/dvd drive is not working. another thing you can do is to take out your cd/dvd drive and plug it back in. to see if it works. if the drive is working, you can try a different XP CD to see if it is working. if it is still doing the same thing. you might wanna check your hard drive to see if it works.
hope that helps.
thanks.
Dec 27, 2007 | Toshiba TE2100 Notebook
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Dvd combo
Did you try axcessing the drive manually ??? Start > My computer > D:(you cd drive),, If it doesnt show up then the drive may be damamged. If it does you just need to associate the .ext with a program. Double click on the drive if a option box doesnt open up, you should see the audio files.. just right click on one and select properties. You should see the program the file is associated with. Just click change and select another program.
Dec 02, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
302 people viewed this question
David Payne
David Payne
