Question about Tektronix Xerox DocuPrint N4525 Laser Printer
N4525 shifted pages
All printed pages including the test prints are shifted so 3 row od print are lost. these lines do not appear on the next page but are lost. this shifting occurs on every page. it is not the logic board, fuser, toner or rollers, no error messages, all suggestions are helpful
2 Suggested Answers
SOURCE: Tektronix 740 fuser
found solution, was the clutch on the accumulator shaft
Posted on Feb 06, 2008
  • 297 Answers
SOURCE: I have a Tektronix 860dp
Fault 07,005.47 is a failure of the drum maintenance system. Having the printer repaired by a certified technician is strongly recommended because the printer's covers will have to be removed, and the printer partially disassembled.
Posted on Jan 16, 2009
0 characters
1 Points
My mp mP830 prints some lines (or partial lines) Consistantly misses the same rows each page
Sounds like the ink is running out at the same time each printing. Check the ink supply. The printer may not be letting you know the correct amount remaining. It could also be the ink jets themselves getting clogged and not distributing the ink enough to compensate for the amount of printing ink, on the page, in time to print all of it in succession. Do a test of no printing except where it seems to be missing and just print that area (print: selection).
Sep 16, 2010 | Printers & Copiers
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Can't get my HP LaserJet 4MV to print. It printed yesterday but now it says "Printer not responding. The printer is on and I have checked all cables. Help
Can you perform a test print? Try this:
To print a Test Menu page
Press On Line] to take the printer off line.
2 Press [Menu] repeatedly until TEST MENU appears.
3 Press [Item] repeatedly until PS CONFIG PAGE (or another PS test page)
4 Press [Enter] to print the page. The page will print in less than one minute.
5 Press [On Line] to place the printer back on line.
Did the printer print? If so, you may have either an nterface or cable problem.
Oct 23, 2009 | Printers & Copiers
The printer prints one page clearly. Given 3
Try to reset your printer to factiry default from it's main menu. and check and you can try uninstalling and reinstallling your printer as well/
Jul 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
When printing some lines don't print properly-appears to be just the top half or less of the line will print. It seems it happens every 3rd or 4th line, but has done it on the second line also, so is not...
Try printing out the test page from the printer, this will show you if any of the inkjet holes are getting plugged. If you can't print a test page without the skipping try changing the ink cartridge(s), the test page will show you which one is clogging.
Dec 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
To align the print cartridges from the HP Photosmart Software
In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
2. Click the Device Services tab.
3. Click Align the Print Cartridges.
The HP All-in-One prints a print cartridge alignment sheet.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Oct 07, 2008 | HP Printers & Copiers
Tektronix Xerox DocuPrint N4525 Laser Printer Logo
Top Tektronix Printers & Copiers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Shahzad  Waseem...
Shahzad Waseem...
Level 1 Expert
Are you a Tektronix Printer and Copier Expert? Answer questions, earn points and help others
