Question about HP OfficeJet 7410 All-In-One InkJet Printer
Paper tray won't feed paper & I get a false paper Jam code
Upon observation it appears that the tray mechanism doesn't lift the paper up to the rollers for proper feeding. I can hear a different sound when it malfunctions and then I get a "Paper Jan in Tray 2" code. The single sheet feed seems to still work.
Look inside, I found a loose spring and replaced it and got one more day of service. Now it is misbehaving again and the spring is still in place. - Co-incidently I noticed my magenta toner is leaking. Don't know if I have 2 problems or 1.
  • 1 more comment
  • Anonymous Jan 24, 2009
    where did you boy the spring?
  • wojciechz Jan 24, 2009
    where did you buy the spring?
  • Anonymous Feb 20, 2009
    We have two of these HP Officejet 7410xi all-in-one printers. Both have developed paper feed problems on the lower tray. The upper tray works fine.
    We cleaned the feeder rollers but it did not help.
    One printer is feeding the sheets from the upper tray crooked. So we have retired that printer for now.
    Has any one had this same problem and if so any fixes?
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Posted on Mar 11, 2009
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
Paper jam error code 13.01.00 hp 3505n printer
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding. A lot of times, it is as simple as the paper backstop has slid back and the roller can't grab the paper that is 2 inches out of reach. Since you've replaced the tray and paper, I would think you might have noticed that. Is the paper moving out of the tray at all?
Jul 04, 2012 | HP COLOR LASERJET CP 3505 N PRINTER
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
Will not feed paper. Can print with manual feed in center of printer, but will not pick up paper in tray. It tries three times and can hear the motors whirring, but then stops trying and the attention...
When you look into the tray with the flashlight, you say the top rollers are spinning, are they touching the paper?
Pull open the tray and while you look from the back with the light, close the tray and see if the paper is being lifted to meet that top roller. Take out all the paper and watch it again. Make sure that the platform that the paper sits on in the tray is free to move up. Sounds like it is jammed.
Also check that roller that isn't spinning. Try to GENTLY rotate it with your fingers. If it does rotate, replace the tray. If the paper in the tray doesn't lift, replace the tray.
Oct 30, 2010 | HP LaserJet 1320 Printer
Printer shows error 13.01.00 and paper jam
Jan 25, 2010 | HP LaserJet P3005n Printer
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Cannot see a paper jam even when the messages say there is a Medi
The paper tray should lift to present the paper to the feed assembly. If the paper tray does not lift then that will require attention and a fairly extensive strip down to replace either the complete tray or just the lift assembly.
Apr 12, 2009 | Konica Minolta magicolor 2300DL Laser...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
734 people viewed this question
Seeker5211
Seeker5211
