Question about Canon PowerShot S2 IS Digital Camera
When I try to zoom, screen goes black and "E18" appears in bottom corner
When ever i try to zoom in or out the camera beeps, the view finder goes black and E18 appears in the bottom left ahnd corner. have to shut off.
  • Anonymous Nov 10, 2008
    same camera same problem. Only I hve to open the batery door to make it "reset" so the lense will retract agian. tho sometimes it E18's before the lense can retract.
    I tried using that air in a can to blow around the lense it helped a little no E18 on start up but if I zoom I get it. :( I love this camera and Im so sad. So far Ive not heard of any fixes excpt to take it in.
  • tmharvin Nov 11, 2008
    Camera was working fine. I went back to it and at first the lens would not extend. I turned it off, then back on and the lens extended but the screen went black and I got the "E18" in the botom left corner and the lens won't retract.
    Problem Solver:
  • 14 Answers
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Posted on Dec 13, 2008
E18 in the lower left corner of the screen and the view finder doesn't work
Canon E18 error happens with lens issues. Usually happens when lens gets jammed
or dirt or sand finds its way into the lens. Sometimes it happens for no reason.
You can try to gently tap your camera on the side and see if that helps, but if it does
it will probably reoccur again at some point. Most likely you will need a lens replacement.
Jan 23, 2011 | Canon PowerShot A75 Digital Camera
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 04, 2009 | Canon PowerShot A70 Digital Camera
Dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
Feb 26, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
Lens won't retract
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed two A400 cameras with this problem by using these methods:
Oct 05, 2007 | Canon PowerShot A400 Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
E18
E18 indicates a lens or "optical unit" problem. In other words your zoom lens won't function correctly. Canon will be more than willing to look after you.
Mar 29, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
PowerShot A70
This comes up when the lens sticks. Try removing the colar around the lens, then turn the camera on/off and give it a "little help" to open or close, it's probably just a little stuck
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
139 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
