Question about ASUS A8N-SLI Premium Motherboard
4GB memory not being recognized
Hey guys, just a quick question before I start playing the which stick of memory is f'd game..
I recently installed 4GB RAM last night (G.SK 400 F1-3200PHU2-2GBZX). All motherboard slots are working fine (just uninstalled 4 x 512MB and computer recognized 2 GB), but my computer is only recognizing 3GB RAM. Every site I look up regarding the ASUS A8N Premium says that it supports up to 4GB. Is there something I'm missing? Do I need to update my BIOS? Could that even be the problem? Or did one stick come DOA from NewEgg,...what's your best guess guys....thanks
  • jayshoe Oct 31, 2008
    Thank you for responding back, I appreciate it.
    All 4 dimms are exactly the same brand and model (4 x 1GB). I pulled all 4 out and reinserted them, and still saying 3 GB...so I don't think installation was a problem if that helps. Thanks again for the response, and ideas would be appreciated
  • Andy Bathgate
    Andy Bathgate May 11, 2010
    are all dimms identical ie same make and rating cos if not this motherboard has dual channel support and any dimm matched pair should go in blue slots but other 2 must also be i dentical to each other and matched in the black slots or system will only read 3 dimms. if only one pair is identical then try putting then 1 in blue socket and 1 in bl;ack socket then add the other 2 this should revert all to single channel and correct sizing error
  • 94 Answers
Check your manual if missing download the manual from ASUS.COM ,saves you listening to bullsh**t
trust me all you need is one matched pair and your poblems are over
Posted on Oct 31, 2008
  • Andy Bathgate
    Andy Bathgate Nov 01, 2008
    try start >all programs>accessories>system information and see how much memory is available to operating system and let me know as collie mentioned before in single channel mode up o .8 meg is given to ICH5 but this should happen in duel channel mode
  • Andy Bathgate
    2.5 System memory
    2.5.1 Overview
    The motherboard comes with four Double Data Rate -Memory Module (DIMM) sockets. These sockets supp system memory using 184-pin unbuffered ECC or no-PC2700/PC2100 DDR DIMMs, and allow up to 6.4GBA
    The following figure illustrates the location of the DDF:
    < m
    5 S
    Q Q
    P4C800 184-Pin DDR DIMM Sockets
    2.5.2 Memory configurations
    You may install 64MB, 128MB, 256MB, 512MB, and 1( the DIMM sockets using the memory configurations in 1
    Important notes
    1. Installing DDR DIMMs other than the re may cause memory sizing error or system I the recommended configurations in Table 1.
    2. In dual-channel configurations, install only id type and size) DDR DIMM pairs for each cha
    3. Always install DIMMs with the same CAS late compatibility, it is recommended that you oM from the same vendor.
    4. Make sure that the memory frequency match (Front Side Bus). Refer to Table 2.
    5. DIMMs installed into any three sockets will f channel mode.
    6. When all four sockets are populated with 1 GB\ the system may detect only 3+GB (a little less! ICH5 resource allocation.
    2-10
    Chapter 2:
    Ha
    2-10
    Chapter 2:
    Ha
  • 756 Answers
To recognize more than 3.5GB RAM you must use a 64 bit operating system
ordinary 32 bit O/S only recognize max of 3.25 to 3.5GB ram
I have a psp e1000 with a sandisk pro duo 4GB I bougth Piratews of the caribbean dead man's chest before the game starts its says"game requires 256KB of space to save. This memory stick only has -299840KB...
The memory-stick is too large to be recognized by the software inside the PSP. Find a 2GB or 1GB memory-stick.
The binary value '0111 1111 1111 1111 1111 1111 1111 1111'
is +(2**31)-1. Add '1' to it, and the binary value '1000 0000 0000 0000 0000 0000 0000 0000'
is either +(2**31) or (-1)*zero, depending on whether the 32-bits are interpreted as either "unsigned-32-bit" integer or a "signed-31-bit" integer.
So, the PSP software cannot handle an integer value that does not fit into a 32-bit word.
Mar 03, 2014 | SanDisk Electronics - Others
Computer doesn't recognise memory stick pro duo 4gb
Hello Guys,
The computer sometimes doesn't recognize the memory stick device due to corruption, there are numerous causes for memory stick corruption for example virus attack, improper removal, wrong usage of the memory stick device and many more. After such corruption scenario data are lost from these devices, but luckily you can recover memory stick files by using an efficient recovery application like Yodot Photo Recovery. Apart from memory stick the tool also recovers files from all other devices like memory stick, hard disk, iPods, music players etc. Try using this tool to recover your data from memory stick
Aug 20, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
Not all installed memory recognized
Open your computer and install one memory stick and try powering on the computer. Try one stick at a time to determine if you have a bad memory module or a defective memory slot on the motherboard.
Jul 03, 2012 | Dell Precision T5500 PC Desktop
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
Help!
nvidia geforce 7100 is actualy not a good card...may be the card is the problem. I could not play this in maximum quality on my nvidia 7600 too. My one worked..but not good. and you have 7100. You shuld think about upgrading your GPU.
Apr 20, 2009 | Ubi Soft Entertainment Assassins Creed:...
Custom firmware
Earlier you have said that you were able to play games from memory stick and since you updated your psp firmware the didn't worked.
First Check your current firmware version . To do this go to
Settings > System Settings > System Information on your PSP . If you your version showing  for example 5.00 M33 you are still in Custom firmware. In this case you should able to play the games from memory stick. or else you memory stick is back... or you custom settings are wrong.
If its showing  for example 5.00 you are with Sony's official firmware. In this case you wont be able to play the games from  memory stick. From here to make your PSP play the games from memory stick you need to Downgrade your PSP. Only way to make this possible is through Pandora Battery and Magic Memory Stick.
So please check your version and let me know so i can guide you further. Also tell me whether your PSP is PHAT or SLIM & LITE..... or check the version of your PSP by removing the battery. Underneth it find some letters and numbers PSP-100x / PSP-200x / PSP-300x
Nov 16, 2008 | Sony PlayStation Portable (PSP) Console
PSP won't recognize the games on memory stick
Earlier Your PSP was installed with Custom Firmware. Thats why you were able to play Backup ISO's from Memory Stick. You have now updated your firmware to Original SONY firmware  and SONY wont allow you to run Backup ISO's from Memory Stick.
If you want to play Backup ISO's again you need to install Custom Firmware
Nov 13, 2008 | Sony PlayStation Portable (PSP) Console
Games on Memory Stick
well, to run games on a memory stick you must have a certain psp hooked up to where you can play games on your memory stick, buying a psp from the store won't let you play games from the memory stick,you must buy a psp game,, im sorry
Aug 14, 2008 | Sony PlayStation Portable (PSP) Console
Save downloaded games
well, you'll require a modified firmware inorder to play games from your mem stick......now installing a custom firmware or downgrading is a risky process , so do it at your own risk! once that's done, you'd require a "ripkit" to compress the image incase if it doesn't fit in to the 1 gig stick.....get ripkits for all games from http://forums.maxconsole.net/
Apr 21, 2007 | Sony PlayStation Portable (PSP) Console
ASUS A8N-SLI Premium Motherboard Logo
442 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
