FixYa.com
Tags:
Canon PIXMA IP5200 InkJet Photo Printer
Can't get connected (by 4 users)
posted by whiskers on Sep 15, 2006
I have just taken delivery of an iP5200 printer, and try as I may I just can't get the computer to find the printer. The OS is Windows 2000 Professional and I have been using a new 'Belkin' Hi-speed USB 2.0 cable. I have tried different USB ports in the computer, rebooted, rerun the provided software and followed the trouble shooting suggestions in the software package but all to no avail. Is it possible that the port in the printer is up the spout? Anyone else had a similar problem?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Dec 29, 2007
can't get connected
Comment by pspez, posted on Dec 10, 2007
My computer is not recognizing the USB connection on the HP 8750 printer. Was working find for a long time until recently. I reinstalled software but nothing happened. I can't see why all of a sudden a USB port would go bad.
Comment by Guest, posted on Nov 29, 2007
it willl load but want start printing process right away
Best Solution
posted on Sep 15, 2006
Helpful (85)
dugiehowsa
Rank:Wiz Wiz
Rating: 78%, 734 votes
There are 3 possible things wrong. You will have to try to test them all.
1) The USB port could be bad. Try plugging another USB device into it and see if the computer recognizes it. Try a USB mouse, portable music player, or any other type of USB device. If it does, then the port is good, and move onto #2. If not, then try another port. If all USB ports are bad, then you will need to have that fixed.
2) The USB cable may be bad. Try swapping out the USB cable. Try using a different USB cable. Also try using the original USB cable with another USB device on another computer.
3) The printer may be bad. Contact vendor support, or just return is to where you purchased it.
Another place to see if the device is even being recognized is the Deviec Manager in windows. This can be viewed by Right clicking on My Computer and selecting "Manage". In the Computer Management window that opens, select Device Manager. If you see any question marks there, then your computer may "see" the printer, but the drivers are not installed properly. If you do not see any question marks or the printer, then there is a problem with the printer.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 07, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Rating: 76%, 113 votes
Yes have the same kind all the time. Try to let the software that came with your printer install your device. Make sure it is hooked up and turned on. Uninstall it first rebooting your computer and then go thru the process with the software from start to finish. Install it all. Then use the software the run the printer. See if this helps. If it doesn't unplug the USB cable for a bit and then with everything on computer and printer plug the USB cable back in and wait for a bit and watch to see if your computer recognizes the printer.
Solution #3
posted on Jan 12, 2007
Not Rated (0)
jbauer
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
wrong, dugiehowsa.
i have exactly the same problem and have not found a fix. the USB port is fine, have connected five other things to it. The usb cable is fine, have connected other things through it.
The printer does not 'ding' when plugged into the PC, does not show in Device Manager, even when manually adding the printer.
All this happened one day out of nowhere. No new software, no viruses, nothing at all. Halfway through printing a page, it spat the page out, made the disconnecting noise, and nothing will make it work.
To add insult to injury, we thought that the 5 month old printer was just dead (IP5200). The printer was replaced by Canon with a new one, IP5300, and NOTHING will make it work. I've even reinstalled Windows overnight, with a full format, and it will simply not work.
If anyone has an answer, please let me know.
Solution #4
posted on Jan 11, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
red light is flasing and printer will print only with manual feed
This Problem Also Relates To: HP OfficeJet 6210 All-In-One InkJet Printer HP PSC 2210 All-In-One InkJet Printer HP LaserJet 1020 Printer HP OfficeJet 7310 All-In-One InkJet Printer HP Officejet J5780 All-In-One InkJet Printer HP PSC 1350 All-In-One Thermal Printer HP LaserJet 2840 Printer
Can you Help with these Printers problems?
ink tank errors
Everytime I try to print I get... Answer This...
REFILLED INK TANKS
lights don`t burn when lid is... Answer This...
print problem
Printer will not print on whole... Answer This...
LA SPIA LAMPEGGIA SEMPRE...
salve, la spia della mia canon... Answer This...
Printer print blue instead of...
My pixma ip5200 print on plain... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
