Question about Ricoh Aficio 1013F Copier
Faxing Problem When I fax the only thing that prints to receipient is the header. the printer, copier, and reports are fine, just the fax contents do not print.
  • bkmcgill Oct 31, 2008
    Ricoh 1013F
    I forgot to mention that it receives faxes good, it's only a problem on the transmitting.
  • 318 Answers
Make and model?
Posted on Oct 31, 2008
Error on hp j4680 image on fax send report is set to on
Sir/Madam
Solution one: Print a fax test
1.Make sure the product is turned on and correctly connected to the telephone jack.
2.Make sure that there is plain white paper in the input tray.
3.On the product control panel, press the Setup button ( ).
4.Press the right arrow ( ) to select Tools , and then press OK .
5.From the Tools menu, press the right arrow ( ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
6.Review the results of the test.
·If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the Fax Test after fixing the listed faxing issues to make sure the test passes.
·If the test does not list faxing issues and solutions, the fax test passed. Continue to the next solution.
7.Try to send a fax again. If the HP fax still cannot send a fax, continue to the next solution.
In case You Still facing Problem The Visit official HP Printer website Below URL Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555948&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3692888
OR
If you Still having Problem then follow Us On:
HP Printer Support
Feb 12, 2014 | HP J4680 Office Jet All-In-One Printer
Does my printer give a confirmation after faxing is completed?
Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
Press the SETUP button ( menu )
Scroll till you find Print Report - Press OK
Scroll till you find Automatic Reports Setup - Press OK
Choose Send Only - Press ok
Regards,
Ron
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
FAX error 390
http://www.fixya.com/support/t591727-error_code_390
Hope it helps!
Mar 06, 2010 | HP Photosmart Premium C309A All-In-One...
When recieving a fax the print speed is at a snail pace. It takes for ever for the printer to print a page of the recieving fax.
try this and let us know. do fax diagonastics.
Test the fax setup from the control panel Follow the steps below to perform a fax diagnostics test.
  1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide .
  2. Make sure you have inserted the print cartridges and loaded paper before starting the test.
  3. Press Setup , 6 , and then 6 . This displays the Tools menu and then select Run Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
  4. Review the report.
    • If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
    • If the test fails, review the report for more information on how to fix any problems found.
  5. After you pick up the fax report from the all-in-one, press OK . Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test.
Accessing the Diagnostic Utility from HP Solution Center The fax Diagnostic Utility can also be accessed from the HP Solution Center software, by selecting the HP Fax enabled product in the drop down box, and then following these steps:
  1. Select Settings , Fax Settings & Setup , Fax Setup Wizard .
  2. Tab through the Fax Setup Wizard to get to the end of the process. This is a good opportunity to ensure that your fax machine is setup correctly.
  3. Click Click here to run the Fax Test . The HP all-in-one displays the status of the test on the color graphics display and prints a report.
Sep 14, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Office Equipment & Supplies
When faxing a 401 error is reported
error 401 means that your number is not programed in the machine you are trying to , so it blocks it
Jan 21, 2009 | Panasonic Workio DP-190 Multifunction...
Faxing multiple pages
If it's only one page.. just place it on the glass face down.
When faxing muliple pages you must place them in the automatic document feeder located on top of the machine.
Place all originals print side up (up to 35 pages). A message will show up in the display letting you know original were loaded up properly. Let me know it this helps.
Apr 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax reports
Hi Jambo,
Please click on the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04517&cc=us&lc=en&dlc=en&product=79477#N1605
Click on the Reprinting faxes in memory and check the steps to print the faxes stored in the memory,
For further information you can go through the web link given above for the detailed overview of faxing.
Have a great day!
Mar 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Aug 07, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
