Question about Frigidaire FDE336RE Dryer
Frigidaire dryer changing 3 prong wire to 4. Dryer has a green wire in the middle not white. Also green wire to ground screw on the frame. where does the white wire of the new 4 wire cord attach. Do I disconnect the present small green wire to frame? Mike
  • Anonymous Mar 21, 2014
    i have a grand hall bbq and there are two igniters with new batteries, has never let me down, could both igniters be bad at the same time. they look like modules with 4 wires on the bottom and two in the middle, one is a ground and there is no corrosion.
    what do you suggest i test ??
  • 1,122 Answers
Ok here is the rule of thumb,the middle wire on a 3,goes to the middle, or white wire always goes on the middle terminal of the block,the black and red does not really matter there both 120 volt but if you can see the wires on the termial block match them up,the green wire gets mounted with the other green wire to the cabinet and your done,let me know how you do-mike
Posted on Oct 31, 2008
Ca't remove green ground screw on dryer
The green wire from the cord connects to the frame of the dryer. If you make some other connection, be sure it is to the frame, not some othe part.
Mar 23, 2014 | Frigidaire GLER331A Electric Dryer
Need help with the green wire ground and white wire neutral
as long as the GREEN wires connected to the dryers metallic case your fine
Mar 08, 2012 | Frigidaire Dryers
Need to change the power corrd to a 4 prong from the 3 prong but the 3 prong cable isnt color coordinated, how do I hook up the new power cord?
The new cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground.
Jun 24, 2011 | Kenmore 62622 Electric Dryer
I need to convert a 3 prong dryer cord to a 4 prong
Hi. Ok, with the rear terminal block cover open, you will see three wires. Black on one end, white in the middle and red on the other end. Use your 3/8′ nut driver to remove the nuts or a Phillips screwdriver to remove the bolts (depending on your dryer) and remove each dryer cord wire from the terminal block. When you remove the nuts or bolts, be careful not to drop them down into your dryer. Next, you need to disconnect the bonding jumper on your dryer. The bonding jumper is either a metallic strap (typically copper or copper clad) or a green wire that is connected between your dryer’s neutral (white wire) terminal and the green ground screw connected to your dryer’s frame. If you removed a ground wire instead of a bonding strap from the neutral terminal, you need to connect this ground wire to your dryer’s frame. Loosen the screws at the connector and pull the cord out. Now thread your new cord through the connector and tighten down. This only needs to be snug do not over tighten. Sometimes the old connector will work with the new cord and sometimes not. If not, your new cord will include a connector that you may use. Now,to hook up your new 4-wire dryer cord, connect each wire to the dryer’s terminal block matching color for color (white to white, black to black and red to red). Connect the green wire to the green ground screw on your dryer’s frame. Once the wires are connected, simply recover the space, and secure the cove with the screw provided.
Aug 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I need to change from a 3 prong to a 4 prong cable. The receptacle on the dryer (Roper heavy duty) only has 3 cables which are color coded red white and black. The new 4 prong cable has an extra green...
the green wire is just a ground,as long as it's touching any metal on the frame of the dryer you're ok,put the wires the same way white in the middle,red on one side black on the other,on the back inside wall where the block is that your wires are connecting to there's a green ground wire in there that you can remove the screw that holds it on and also connect the new ground wire with it or like i said you can remove any screw that's close to the block and ground the wire there as long as it's grounded to the frame of the dryer
Apr 18, 2010 | Roper RGX4634KQ Gas Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
Changing my dryer cord from 3 pronge to a 4 pronge. how do i hook the cords to the baqck of the dryer. brand name is a frigidaire
on 4 wire, red and black is hot, white is neutral and green is ground. On terminal block out side terminals are hot and center is neutral, ground connects to green screw on cabinet. if your current connection has a white or green/yellow jumper on the ground term move this to the center/neutral connection with the white wire. only wire to be on gnd term in gnd wire. hot does not matter which side as long as it doesnt touch anything else and not on center term.
Difference in 3 and 4 is a dedicated ground, on 3 wire dryer was grounded through the neutral.
May 03, 2009 | Dryers
3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Oct 31, 2008 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
66 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
