Question about Keurig B100 Coffee Maker
Keurig B100 not pumping a cup of water through
After taking the machine apart, I have determined that the hoses are free of clogs. However, it is only pumping a small amt of liquid (1T). For example when pot is empty of water; on first cup water pumps thru tube to top of heater storage, on second cup the water pumps to end of tube, on third cup water pump about 1T into actual cup. Any ideas of where the problem is?
  • 6 more comments
  • mmcdev60 Dec 09, 2007
    I also have a Keurig B100 which is having the problem of lack of water flow. I have repaired the worn tubing connecting to the baffle. However, when the dispenser is activated you can see the water creep up the tube to the dispenser but there does not seem to be enough pressure behind it to be dispensed. There is air being pushed though the tubes on the left of the machine.
    The appearante problem seems to be that the check valve for the pump on the right side of the machine was failing and allowed water to drain into the air pump. Is it possible to get a replacement check valve and pump?
  • eddiemcgough Mar 09, 2008
    We have had our B100 for 4 years and it recently stopped pumping water into the cup. If you remove the left side panel you can see the water flowing up through the tube, but slowly and it ***** reaches the cup. I have tried to read and understand the solution that is posted, but the English is very bad and I do not understand the answer.
  • Anonymous Apr 24, 2008
    I have the same problem. The solution mentioned below was not my issue. No tubes at or near the baffle were cracked or split. I could not find the cause of the problem. It just seems like there is no pressure any more to push the water thru.
  • Anonymous May 19, 2008
    I'm having the same problem
  • stoneunicorn Nov 17, 2008
    I have the same problem. Sometimes I get a very small amount of water in my cup and other times I get more.  I will try to do what I read here but I am not sure I understand all the instructions as the English is not great.  I hope I can fix it, we'll see.....
  • Anonymous Mar 25, 2014
    How do I prime the Keurig to get it to pump water
  • Anonymous Mar 28, 2014
    brew size not right and water pumps out of top water valve
After dismantling the B100 and trouble shooting the machine I determined that the hose leading to the air pump on the right side of the B100 allowed water to back flow into the motor. The small amount of moisture eventually caused the motor to fail.
I had to find a scrap machine, which most people that have bought this piece of equipment have just thrown it in the trash, and remove the motor from the opposite side which still functioned. Since it is designed to mount to a specific side I had to appoxy the motor into place. To keep the problem from occuring again I purchased a check valve from a local pet store and put it in-line with the motor.
This solved the problem at the source and has prevented moisture from getting into the motor. Now I am a proud owner of a Frankin Pot. It's alive!
Posted on Oct 22, 2008
    Problem Solver:
  • 13 Answers
In the water tank you have 2 sillicon tube one of them is stretch at maximum and usaly strech in 2. cut the part split and connect it again. the probleme is because the silicon left is propryety when is strech in very hot water. the best way to slove this problem is to find about 1 in of silicon tube of 1/4 or 3/16 iner and put the new parts of tube directly on the bafle and put the original tube in the new on. it just make a link betwen the bafle and the original tube. put teflon tape on the fitting of the bafle to avoid of the new tube spout out from the fitting.//// but take care and other touble can cause this the pump can be jam because the one way valve on the side of the brewer jam open because is to teith in in is body. check all is thing .if you need somthing eles y will comme back on the site soon :0)
Posted on Jun 17, 2007
    New Friend:
I've cleared the hoses, checked the pump (blows air fine), made sure the check valve was working, but when I blow into the hose, I can hear water bubbling in the tank, but none is forced up the brew-feed side. Got a lot of it apart but I don't know how that water feed hose is supposed to work and I can't seem to get into the boiler. The hose just seems to be forced through a very tight hole in the top of the boiler.
Posted on Jan 17, 2015
Take case apart until pump assembly can be seen..remove pump assembly ,carefully pulling from body of unit and throw it on the floor.now the keurig will be lighter and more suitable for the trash bag.
what a piece of chinese turd.
Posted on Nov 01, 2008
I have found that the pump on the right side ( looking at the front of the machine ) must have a hole in the rubber diapham because I found water around the motor shaft. Cleaning this and lubing it with some light oil ( which doesn't come into contact with any water to the tank ) seemed to help for a while. But it has since quit altogether. I wish someone else would make a brewer to accept these cups other than Keurig. The B100 was U.S. made and was pretty quiet. Now all the makers are made in China and sound like cement mixers. Our ( new ) B40 actually moves the cup around because it vibrates so bad. Any companies want to joint venture into a brewer to accept K Cups? AND make it in the USA? As a small manufacturer, I feel the need. Regards, Rich.
Posted on Oct 21, 2008
For some water issues pressure switch above brew pump "right hand side", has an adjustment on rear side "hidden". Try playing with this, after ensuring all hoses are o-k. Turn cw for more water ccw for less.
Posted on Sep 06, 2008
My mr.coffee keurig model VBMC KG5 single cup coffee maker will not run a whole cup during cycle
The Keurig machine operates by pumping air into the glass boiler to drive the hot water through your coffee cartridge. When you have put a new cartridge into the dispenser, you select a size of cup. When you press the go button, you should hear the machine pump water into the boiler to the requested cup size (test by selecting large size to hear the pumping work). Next the machine operates an air pump to force the specific amount of hot water through the cartridge and make the cup of coffee. The problem encountered with these machine is that a small amount of water can drip internally onto the air pump and it will either not operate or work intermittantly. There is a great 'how to fix' video on utube concerning the Keurig-taking apart and fixing.
Honestly, I don't know whether this is your problem, but I do know this happened to a machine I had. You should hear the tiny air pump working when the cup of coffee should be brewing. You can laboriously take apart and replace, and given the price of these units it may be practicle to do the repair. Watch video on utube--its like three or four parts and very instructive. Sorry I don't have the link.
Jan 09, 2014 | Keurig Platinum B70 Coffee Maker
I have a keurig mini and the water is barley dispensing. I dont know if its clogged or what. What can i do?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 04, 2011 | Keurig B100 Coffee Maker
Keurig b100 does not shoot water in the K-Cup, It
Either it is scaled up and needs to be cleaned or the air pump is bad.
Nov 08, 2009 | Keurig B100 Coffee Maker
Only pumps out 1 oz. of water into the cup
Try to de-scale and clean the Keurig machine. Use citric acid or purchase a product called De-scale. If the unit is thourghly cleaned and will not pump our water, the pump is out of the machine. Replacement pumps cost about $25.00. Considering the B100 retailed for $338.00 it may be worth it. You can send it out to repair at crystalpure.com. Repairs for an air pump typically run about $50-75 depending on the exact problem.
Nov 06, 2009 | Keurig B100 Coffee Maker
My B100 Keurig stopped pumping water
This is a very common problem, just call Keurig tech support. Explain the problem and they will send you a replacement unit and you get to keep you old partially functional unit. I bought mine in December 2009 and I'm on my 3rd unit already. They keep having the same pump issue and Keurig just keeps sending me replacement units. Their customer service is great, but I'm beginning to question their quality control.
Aug 24, 2008 | Keurig B100 Coffee Maker
Keurig b100
It sounds like one of two things happened when you disassembled the unit. Either the hose that controls the mechanism for the piercing arm (the part that puts the holes in the k-cup) became disconnected or pinched, causing the water to pour out over/around the k-cup. Or the k-cup holder is clogged or not seated correctly, which would cause the same problem. As for the little button you may have pushed, that can't cause the problem you're experiencing, so don't worry about that. Good luck, let me know if need more help. Erik
Jun 25, 2008 | Keurig B100 Coffee Maker
B100 Keurig
The pump is on the right side, has two wires coming out of it, and is connected to the check valve with a silicone hose. When you run a cycle, to brew a cup of coffee, that pump should be pumping air out, which pushes the hot water out of the tank.
So to test it, disconnect the hose and run a cycle to listen and feel for air coming from the pump. If it is not working (frozen due to the water permitted to enter from the failed check valve), you must remove it to dismantle the top part of the pump.
Getting the pump out is a little tricky... as you will see. There is only one philips head ***** holding it in, however, it is not easy to get to. I used a 90 degree angled *****driver, which worked well, after trying many other options.
Once you get it out, remove the three philips head *****s on the top of the pump right near where the hose was connected. Then separate the two sections of the pump. Inside there will be a fitting in the center that spins to actuate the pump. This fitting must be freely moving. If it is not, use WD-40 or a similar product to free the motor.
Clean up all the WD-40 from inside the chamber (so your coffee does not taste like oil) and reassemble. Then test it by running a cycle. The pump should now be working, if not repeat the process until the pump operates.
Since my last post, I have fixed another B100 that had the same issue. Keurig will not sell you a replacement pump or check valve, so you must repair that pump.
Good Luck, I hope this works for you. Erik
Mar 10, 2008 | Keurig B100 Coffee Maker
Delivers only small amount of coffee per brewed cup
this is not a scale issue, mine arrived from the factory producing only 6oz of water. way to strong for most. called the factory, scale, scale blah blah blah, vinegar untill we were blue. bored one day took the unit apart. on the right hand side there is some clear tubing which housed a one way valve, took apart and the valve was partally clogged. removed cleaned and reinstalled, this valve works best when not fully" seated" where it belongs so reinstall gently into the hose and leave it alone. I know what your thinking scale, scale scale. wrong. still only made 6 oz cups. there is a timer device on the back wall of the front panel on the right side as you face the unit. it is adhered to the wall with two sided tape. pry it off and on the back low and behold is a timer screw that changes the length of pump run time. turn clockwise with a sharp knife or eyeglass screwdriver and retest. 9oz of water. shame on keurig for not being more responsive to its customers.
Jul 23, 2006 | Keurig B100 Coffee Maker
Keurig B100 Coffee Maker Logo
6,632 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
