Question about HP f2105 21" LCD Monitor
Monitor's backlight inverter shuts down.
After a minute or so the inverter shut's down, so no light, and no picture.
Turn off and on the monitor brings the inverter back to work for a minute or so.
I turned the small potentiometer on the inverterboard, there seems to be a little influence on the time.
Seems that there is a component overloading protection misadjusted or so.
Does anyone have a schematic on this board, or an idea how to save 90 bugs to buy a new inverter?
Many thanks.
Marc
  • 2 more comments
  • mkieffer Oct 31, 2008
    It's a computer monitor from HP.
    Model HP f 2105.
    model from HP HSTDN 2B05
    product number P8727AA
    As i opened everything, can see that all the internals are from BENQ
    The part number of the inverter seems to be 48.L1S04.A01
    I'm quite good in electronics, so you can put details in your help.
    Many thanks.
    Marc
    The video source can be excluded,as i have tried already different sources.
    Just touching the potentiometer on the backlight unit with the screwdriver, sometimes makes it shutdown already,depending of the position of the potentiometer.
    Looks like if the oszillator switches off.
    On the backl.unit is a 9 pin connector for the power.
    Colors and voltages
    black 18.95V
    brown 18.95V
    red 18.95V
    yellow 0V
    orange 0V
    green 0V
    blue 3,27V
    violett 0V
    grey 0V for normal operation. 3,27V when backlight fails.
    So far for my analyze now.
    More news....
    Just took off the grey wire from the connector i told you before ( 9pin backlinvert.)
    The voltage on the wire goes up to 3,28 volt, but the monitor continues working.
    So it seems that this wire comes from the control unit and tells the inverter to switch off.
    What purpose is it??
    The monitor continues working.
    Funny.
    Brigadier General:
  • 6,966 Answers
Initially, visually inspect for any leaked or bulging capacitors. The problem may be heat related. In the absence of a schematic diagram, you may have to wing it. To verify if it is heat related is to have a can of compressed air or "instant freeze". Soon as the unit shuts down, spray suspected area. If unit resumes operation, you have pinpointed the area to start component check. If it is a major problem, the unit will not even start up. But since it works except shuts down, then again as initially posted heat related.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
  • Louie  Role
    Louie Role Oct 31, 2008
    A couple of standard tests/ideas:
    • it is rare for all CCF (cold cathode florescent) lamps to go out at the same time, hence least likely;
    • to confirm if it is the backlight/inverter shutting down, shine a flashlight at an angle across the LCD display screen when the CCF lamps go out. You would still see a semblance of desktop except it would be very dark, if yes, then it is backlight/inverter issue;
    • if not then it would be a video interface or controller issue (again unlikely);
    • pls check voltages of the PSU, in most models, the voltages needed are 12~15, 5 and 3.3. They should remain constant even if the lamps shuts down.
    Again, no exact service manual could be located. But as you posted "good in electronics", then these might be of help:
    Hopefully the above would at least give you an idea.
    Brigadier General:
  • HP Master
  • 3,614 Answers
What is the exact model maker of the tv...? and also if you can provide the part # that would be great.!
  • 1 more comment
  • micromaster
    micromaster Oct 31, 2008
    Do the following items to prepare for troubleshooting:
    • Turn off the computer.
    • Disconnect
      all connected devices from the computer except the mouse, and keyboard.
      This includes removing thumb drives and camera-type memory cards.
    • If the monitor has a detachable cable, obtain a second monitor cable for testing purposes.
    1. Turn on the computer and press the
      F8
      key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select
      Enable low resolution video (640 x 480)
      , press
      Enter
      , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document,
      Changing Display Settings, Background Image, and Screen Saver in Windows Vista
      If you are using Windows XP, select
      Enable VGA Mode
      , press
      Enter
      , and wait until Windows opens. Continue using these steps to set display resolution.
      If you are using Windows 98 or ME, select
      Safe Mode
      and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click
        Start
        , and
        Run
      2. In the Open field type
        msconfig
        and press
        Enter
        The MS Configuration Utility window appears.
      3. Click the
        Advanced
        button, and select
        VGA 640 x 480 x 16
        if it is available.
      4. Click
        OK
        and restart the computer.
      5. After Windows opens, click
        Start
        , and then click
        Run
      6. In the Open field type
        msconfig
        and press
        Enter
      7. Click the
        Advanced
        button, and remove the checkmark next to
        VGA 640 x 480 x 16
      8. Click
        OK
        . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select
      Properties
      (Windows XP, 98/Me) or
      Personalize
      (Windows Vista).
    4. In Windows Vista, Scroll down and click
      Display Properties
      In Windows XP, 98, or Me, click the
      Settings
      tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to
      Highest (32 bit)
      In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to
      Highest (32 bit)
      In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to
      True Color
    6. Click
      Apply
      after you have made your adjustment.
      The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click
      Yes
      on the Monitor Settings windows. If you are not satisfied or if the
      screen just goes black, wait: Windows sets the screen back to the way
      it was before. Try another setting until you find a display
      configuration that is compatible with the monitor and meets your needs.
      NOTE:
      If
      the native resolution is not available, download and install updated
      video driver software for your computer. Updating the video driver
      software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
  • micromaster
    it seems that you already open the monitor. its better first check that you have that problem only on that monitor. try this;
    Using a different cable, connect the
    monitor to another computer that has video. Turn on the monitor and the
    newly connected computer. What happens?
    • If
      the monitor works, the video hardware on the original computer is
      likely to be the source of the problems. You can try connecting the
      original computer to another monitor that works to update its video
      drivers.
  • micromaster
    Checking the back light unit
2 Suggested Answers
SOURCE: HP f2105 LCD monitor Backlight inverter problem
Simply open the set and cut that GRAY WIRE ON THE SET OF WIRES THAT CONNECTS THE POWER SUPPLY TO THE INVERTER CIRCUIT. 100 PERCENT WORKING AND TESTED BY ME. (hardwareman25 @ www.gsmhosting.com or email me @ kiwakulecho.gsm@gmail.com )
Posted on Sep 24, 2011
Monitor goes to white when I turn it off.
If it turns white when you turn the power button off, then what is happening is the video part is getting turned off, but the backlight bulbs are staying on. This means the inverter board is not shutting off.
This could be caused by low power in the power board which may be failing from age or the inverter transistors are not shutting down after they heat up.
The boards would have to be rebuilt.
Since it is a 17 , it may not be cost effective.
Unplugging the power cord will work for a while to turn it off. It is just inconvenient.
If I saw a picture of the boards, I may be able to tell you for sure if the problem was obvious. I repair monitor boards through ebay.
Search bammbammfran
Oct 27, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Monitor goes on then off right away.
The backlight inverter is faulty.
THis means that there is either a loose contact or one of the transistors on the backlight inverter has blown
Jul 06, 2009 | HP Pavilion F1703 17" LCD Monitor
Flat screen monitor
Possibly a bad inverter that turns on the fluorescent backlight or a bad bulb.
Jan 17, 2009 | Envision EN-7100e 17" Flat Panel LCD...
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
Monitor is blinking out
Hi...there,
It's seems you got a busted backlight inverter problems...
Dec 17, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Oct 31, 2008 | HP f2105 21" LCD Monitor
17" AOpen monitor about 2-3 years old
Sounds like a backlight problem.. due to the inverter shutting down due to a fault.
Jun 21, 2008 | Acer AL1715 17" LCD Monitor
HP f2105 21" LCD Monitor Logo
1,384 people viewed this question
Top HP Computer Monitors Experts
Tony Isted
Level 1 Expert
Nicola Conroy
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
