Question about AOpen AX45-V (91.88I10.004) Motherboard
No Display on screen?
Here is my problem, I have installed this AX45-V motherboard and there is no output from the video card. I think that I have everything set up properly, everything is running and all of the lights along with the fans are on. The processor is fine, the processor works on another pc. Even though you can not see the POST there seems to one long beep now, but it runs continuously, but you have to wait about 3-5 minutes to hear it, I am running AWARD BIOS, although when I look it up is just says that it could be a video problem, I have used the card in another computer, and I have used diffent cards in this computer, and the compound on the processor is fine. p.s. This is a follow up on my earlier question "No Display On Screen"
  • 883 Answers
Try using the "RESET" jumper
Posted on May 20, 2007
SOURCE:
Nv5207u gateway the power light come on , but the screen will not come up and I think it stop trying to start up. I can hear it stop
If you can, try and connect your laptop to an external display and see if it outputs to that display. If so, you may have an LCD or video card issue. If not, it could again be the video card or the motherboard. Look for blinking lights when powering on the machine. These can oftentimes be errorcode displays.
Mar 23, 2013 | Gateway NV5207u Notebook
P5PE-VM with Win7 has no display on PCI video cards-EVGA 2600 or EVGA gt 220. Both cards ran fine with Win XP. What do I need to do?
Hello here is the mainboards homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Are you running 32 or 64 bit system ???
Make sure the video driver supports windows 7, 32 or 64 bit.
The video card can sure run fine on windows xp but not in windows 7 as it is a totaly different system.
The mainboard has a 1 x AGP 8X slot.
So now you maybe has to find a video card that supports windows 7
Try also to download a manual.
Good luck
Dec 04, 2012 | ASUS P5PE-VM Motherboard
Catalog of Motherboard AOC AX45-V say that this motherboard support 3 memory cards of 2 types up to 3 GB, DDR 266 or DDR 333. If I use DDR266 can be installed in any slot, but I f I use DDR 333 can be...
either can be installed in any of the 3 slots, there is no specific spot for any. It's never guaranteed it will work specially if you deal with different type of memory modules.
May 04, 2011 | AOpen AX45-V (91.88I10.004) Motherboard
My intel d848pmb motherbord in not giving display how to solve it reply me on my id Atiq_killer@yahoo.com plz i m wating for ur good ans
You have an integrated video card on this motherboard? AND u are not getting output to your Monitor? If so, install another video card to see if u will get output to the monitor. If u do, your video output problem is solved. If the integrated video card is the only thing not working on the board, then u can continue using the same board as usual. Be sure to remember to plug ur monitor into ur new graphics card.
Mar 15, 2010 | Intel D848PMB Motherboard
I have a Nvidia gforce 7100 that will not display thru s-video
boot in safe mode. safe mode will not use your settings. Once you have booted in safe mode then you can reset your video card.
Jun 06, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
No display out of asus p5gl-mx motherboard, even i use video card
check the memory, then clear the cmos and try rebooting before you think the worst
regards
Nov 22, 2008 | ASUS P5GL-MX Motherboard
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
Beeps
You have an Awared Bios. The link below details what your bios beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
I suggest you remove your memory & re-seat it & do the same for your video card to be on the safe side.
This next link list some basic's about your board.
http://www.pcstats.com/articleview.cfm?articleID=1008
Good Luck.
Mar 14, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
No Display on screen.
If available, try using a different video card to see if it will POST. The only other thing I can think it might be is that the processor isn't seated correctly, or that it is seated correctly but you have too little, or too much thermal compound on the CPU.
Sep 15, 2006 | AOpen AX45-V (91.88I10.004) Motherboard
AOpen AX45-V (91.88I10.004) Motherboard Logo
63 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Joaquim Martins
Thomas F. Schneider
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
