Question about Hoover Washing Machines
How to release new carbon brushes in their holder
  • jiffy 1 Nov 01, 2008
    the brushes were held back in their holder for transportation only.the holder had to be split open and a metal tab bent back to release the carbon brush.THANKS
  • 903 Answers
All carbon brushes have an electric wire attatched to them, that needs to be gently praised off (make sure the machine is unplugged from electrical outlet), then using a flat headed screw driver, push in the clip that is holding the brush in place and at the same time gently pull the carbon brush up.
To replace the brush, simply push it back into its slot (but gently and carefully because it can snap) until you hear a click then replace the electric wire.
If you have left the rubber band on the brush when you inserted it back into it's holder, simply cut the band at the top and very gently pull it up until it is removed.
Posted on Oct 31, 2008
Where can i get new brushes for 24volt motor on a landlex gazelle s420
most any appliance repair shop or auto electrician will have generic brushes that can be trimmed to fit the holder
take a brush to show as an example
Sep 17, 2016 | Health & Beauty
Carbon brush has broken and is stuck in so i cannot put a new one in, on Einhell sliding mitre saw
If you cannot get the carbon pieces and/or spring out of the brush holder your only option is to take the saw apart and remove the armature. From there you can either push the carbon piece(s) through or out from the other side. It will also give you a better assessment of any damage caused to the brush holder and armature contacts.
Feb 22, 2012 | Saws
Cannot get clothes out meesage e30 what can I do?
Hi, E30 indicates a fault in the motor circuit, unplug the appliance and take the top off. Either side of the motor you'll find a carbon brush holder. Disconnect the wire to the carbon brush and take the holder out. If worn or broken, replace with new ones.
Jul 14, 2011 | Hotpoint Ultima WD72 Front Load...
I have a aeg ph38 electric 800 watt chipper hammer, i need to find carbon brushes and the carbon brush holders for the tool.
RE AEG PH 38 Brushes go to local hardware storeinthe miscelleanous everything aisle and look or a SKIL brush set exact size match $4.50 US cost I fixed mine today. Brush holders another issue
Apr 25, 2011 | Garden
Rear wheel sticks and sometimes when you go to go forward nothing l of a happens,then al of a sudden it jurks forward with no warning.l
Hi. Sounds like you have worn out motor brushes. the brushes wear down to short and get stuck in the brush holders. Sometimes the caps that hold the carbon brushes in come loose, and the carbon brushes get stuck because the current arcs between the carbon brush and the brush guide. Get a serviceman to overhaul the motor, and it will work fine. Probably a good idea to replace the motor bearings at the same time. Good luck. Neil.
May 27, 2010 | Pride New Mobility Legend 4 Wheel Scooter
How to change carbon brushes
You need to know that very seldom will new carbon brushes alone `FIX`a motor in todays vacuums as they are higher RPM than those of 30 years ago.
On a salvageable motor a good rebuild procedure will generally include repacking bearings, cleaning suction fans and reseating new brushes with an abrasive seating stone at low speed with a motor run in device with variable voltage
That said, I have not done a HENRY in years but it likely will contain a generic AMTEK Lamb type motor as it is sold as more durable vac.
On a traditional vac motor, carbon brushes are removed by releasing a clamp over the brush. The brush holder will have either a flag terminal on it where the wiring will disconnect from the side, or a flat flag terminal which slides into a pocket on the carbon brush housing.
. If you are going to the trouble of replacing the brushes, remove and inspect the old ones for wear and chipping. Also inspect the commutator surface on the motor where the brushes contact. If there are any curved gaps between segments, or if the com is worn like an apple core , you need a motor complete.
If the motor has simply worn to the point where a brush has stuck or worn to nothing, you may be bale to reseat the new brushes, however any evidednce of BLUE sparks or noise is not a good sign . Best of luck. Post back if you need more help
Nov 01, 2009 | Henry Numatic "" Canister Vacuum
Replacing carbon brushes of csb 500 re bosch drill
bosch brushes are unique. they have a spring embedded in the carbon so when the length gets too short, the spring lets go and raises the brush above the commutator and the appliance stops. you need to remove the handle partially or the brush covers and unscrew the brush holder(s) two small screws secure the brushes and holder to the appliance.
Oct 13, 2009 | Bosch Drills
Hotpoint WM 22 wont spin
The first you need to do is check the brushes in the motor.
Remve the screws at rear of top cover, remove cover.
Slacken off the 2 bolts securing motor,and remove belt.Remove 2 screws that hold motor and lift motor up so you can access the brushes..
The brush holders will be either black or white, depress the plastic lug that holds the brush in place, and slide the holders out, remove the wires to the brushes, and check the carbons, if their is less than 2 or 3 mm left, then replace them.
Only fit the genuine brushes, and if you can make sure you fit the black ones, as they are better than the white ones.
Follow the instructions on the packaging on how to release the carbons from the captive position.
Refit motor, and ensure the belt is reasonably tight.
If it still does not work ,then the motor itself could be faulty, check for broken wires in the motor plug and harness.
Plz rate my solution.
Jan 03, 2009 | Washing Machines
Bosch wfr2460
hi Many universal motor malfunctions are caused by wearing down of the carbon brushes, the soft blocks of carbon that complete the electrical contact to the motor's commutator. When these brushes become worn, the motor will spark, and electrical contact may be incomplete.try this
Step 1: To sight-check the carbon brushes, remove the screws that hold the brushes and brush springs into the brush holders at the sides of the commutator. The screws will pop out of the screw holes; turn the motor over to tap out the brushes. The ends of the brushes should be curved to fit the commutator; if they're worn down, new brushes are needed.
Step 2: To check carbon brushes with a continuity tester, remove the motor lead wires from the circuit. Tag the wires as you disconnect them so that you'll be able to reconnect them properly. Hook the tester clip to one motor lead and touch the probe to the other lead; the tester should light or buzz. Slowly rotate the motor shaft, keeping the tester in position. If the tester doesn't light or buzz, or if it flickers or stutters when you turn the motor shaft, the brushes should be replaced. If the springs behind the brushes are damaged, they should be replaced as well.
Step 3: Replace worn carbon brushes and damaged springs with new ones made specifically for the motor. The model information (number and make) is stamped on a metal plate fastened to the motor, or embossed on the metal housing of the motor. If you can't find the model information, take the worn brushes and springs with you to an appliance-parts store to make sure you get the right kind. Insert the new springs and brushes in the brush holders, replace the brush assemblies, and secure the new brushes with the mounting screws that held the old brushes.
Sep 13, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
How to change carbon brushes in Vax 2000
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. This is tricky but can be done.
Aug 31, 2008 | VAX Appliances Vax X5 Bagless Upright...
Washing Machines Logo
102 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
