Set key counter
Ricoh aficio 450 code error set key counter plz
jaylex
  • 417 Answers
SOURCE: error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Posted on Jan 06, 2008
spinal
  • 287 Answers
SOURCE: Ricoh Aficio 1224c
Hello billboards,
SC 570 means that despite the fact that the the copier had been giving a "FUSER OIL LOW" prompt in the upper left hand corner of the display for quite some time, the prompt was ignored and now the oil is more than low it is empty. You will first need to aquire fusing oil for your machine.Typically it would be purchased from the same source you would aquire toner as it is something that is consumed as the copier is used similliar to toner. Once you have the oil you will need to replenish the copier's supply of oil. To do this you will need to access the back of the machine. Once you are at the back of the machine,look down to the lower right hand corner. You will see a small square panel with what I would describe as an oversized white plastic flathead screw that needs to be turned counterclockwise to release the small panel/cover. Once you remove the cover you will see a clear container witha black screw on cap. Unscrew it,and fill the container with the oil and stop filling when it reaches the neck of the container. Button everything back up and now you are halfway out of the woods. Now we go to the front of the machine. We need to reset the code. There is a yellow rectangular button above the nine key pad used to enter the number of copies you want. Now that you have located it, press it once and then press the "1" then the "0" then the "7" and then press the round red stop button and hold it down until the screen changes and beeps. At this point the display will have several blocks showing. One of the blocks will say "copier".Press the copier block. Now you will have a drop down menu to the left and several options across the top of the display. At the top,from left to right,the fourth box should say "SP DIRECT" and should actually already be highlighted. At this point,merely press "5810" on the keypad and then press the " # " pound sign. The pound sign means enter. At this point you should see a prompt that says something like "SC reset" and there will be a bar below the prompt that says "EXECUTE" .Press the execute button. This resets the code. But now you must turn the main power off (the red switch located next to your left knee on the front panel of the copier) and wait a few seconds. Now turn that switch back on and you should be good to go. I just reviewed my instructions and wanted to stress that the yellow button above the nine key pad says clear/stop. Just wanted to be more specific. I bet you have this problem whipped in no time! I hope this helps.Take care and good luck.And please feel free to let the folks at "FIX YA" know if I helped you. I don't get paid by them but I like the pats on the head . :-) ...........spinal.......
Posted on Apr 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
SOURCE: Ricoh aficio 450 error code
set key counter plz
Posted on Oct 31, 2008
Aficio 350e error code sc547_00
fuser unit error ,go to simulation i.e press 107 and press cancel key and hold then switch off machine an on
Aug 11, 2013 | Ricoh Aficio 450 Copier
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
ERROR of My Aficio MP1500 Photocopier
Are you sure about the model number? I believe you may mean MP2500? Regardless, sounds like an NVRam Problem. This unit is what controls the electronic counter, as well as most of system settings. This will require a service technician from a dealer with connections to RICOH.
Feb 25, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Jan 29, 2009 | Ricoh Aficio 1035 Copier
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
80 people viewed this question
k24674
jasbo
jasbo
