Sky tv constant tech problems,cant watch all channels
I am dumb and I have a problem
Posted on Nov 09, 2008
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
How can i tune all my sky channels to my dvd/vcr combo box
Hi sounds like the remote may be in the wrong mode , you can scan channels into the sky box or the TV/combo.
Make sure you are scanning them into the box not the combo.
Jun 14, 2012 | Daewoo Televison & Video
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
CAN I STILL WATCH SKY TV THROUGH MY TV WHICH HAS FREEVIEW BUILT IN
yes...via scart or hdmi (depending if you have sky hd) tv will need to be set on AV1 or HDMI channel when watching sky tv. normally selected on your tv remote with a button with a square and an arrow pointing into it or simpally AV written on the button.
Mar 19, 2010 | Sanyo Televison & Video
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Problem when watching box office movies
There are two things that may be going wrong.
Sky box office are transmitted on different Transponders. I'll explain, each transponder has a different number.. each one has 10 channels or so on them.
this would explain why you can watch regular tv channels but have pixelating on box office.
your sky dish may need to be re-aligned or the LNB (bit on the end) may need changing
the other one is if your box is old then the tuners maybe on there way out. hense you losing certain blocks of channels.
May 26, 2009 | Hitachi HL01453 Remote Control
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Jul 20, 2008 | Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Picture problem when I use an external antennae
You cant unless you have been trained to trouble shoot solid state electronics as this set has no user serviceable parts inside and is best left to the pro tech to service. good Luck
Aug 08, 2006 | RCA F27645 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
