Question about Apple iPod MP3 Player
Ipod 20 gig
The pod will display the Apple then an exclamation/folder icon. Thats it; no sound. Help please & thanx.
Well, unfortunately this problem is kinda vague (it's not your fault, the error itself is just very general and doesn't always indicate a specific problem). In fact, you will probably have more trouble figuring out what the problem is, as opposed to actually resolving it. The official Apple response can be found at http://docs.info.apple.com/article.html?artnum=61003 and basically suggests one of four things 1. Charge your iPod (I suggest fully discharging it over a 48 hour period then plugging it into an outlet for a couple of hours so that it becomes fully charged) 2. Reset your iPod (http://docs.info.apple.com/article.html?artnum=61705 that site has the information on how to reset any model iPod, but for the most part, most recent iPods can be reset by holding the "menu" and "select" buttons simultaneously for a few seconds) 3. Resore your iPod (connect the iPod to your computer and run the iPod updater or iTunes, depending on which version of iTunes you have. If they reconize your iPod, select "restore" but be aware that this completely erases your iPod. If it does not recognize it, go into disc mode on your iPod by holding down the "play" button as it is starting, and try to connect it to your computer once more) 4. If none of these work, you may unfortunately have a "dead" iPod. This can be the result of physical damage to the case of the iPod (even a small dent can cause the hard drive to stop functioning). The hard drive may also have just died over time. Finally, the battery may have lost its charge over time. Fortunately, you can probably take your iPod in to the Apple store and they can resolve any of these problems, or you can send it to Apple to be repaired (go through their site and they will tell you how to go about doing this). Regardless, don't count on Apple to fix this for free, if your lucky they may give you a break, but most of the time the will tell you that neither the battery, nor any sort of physical damage is covered by either the 90 day warranty or AppleCare. Alternatively, you can replace either a dead hard drive or battery by purchasing one from a third party and installing it yourself. For more help, you might want to try the iPod troubleshooter http://www.apple.com/support/ipod/tutorials/troubleshooting.html
Posted on Jun 04, 2007
    Scholar:
  • 41 Answers
Firstly, I'd try resetting your ipod. As with all clickwheel iPods, you can reset it by first toggling the hold switch on and off and then pressing the select (center) and menu buttons at the same time for about 10 seconds. When it's turned back on it will show the apple image for a few seconds and then continue. (Note, this does not delete your music) I have heard of other cases where lockups can be solved by either charging the battery, or if the battery is already charged, letting it drain the power, then connecting it back to your computer. (I am not certain the reason this fix works, but it has been confirmed on more than one occasion.)
Posted on Sep 15, 2006
SOURCE:
Apple i pod not responding
if you cannot get itunes through the computer just download music through the ipod itself thats what i do or you can take it to a pcshop and they will repair it for u
Aug 09, 2012 | Apple iPod nano
I pod displays "connect to power" then shows
It sounds like your battery is bad. They can be replaced readily easily. Batteries an be found on eBay for as little as $5 and directions to replace it can be found here:
http://www.ifixit.com/Browse/iPod
Jul 26, 2011 | Apple iPod MA446LL/A MP3 Player
My ipod mini 4gig has been corrupted. trying to restore but unfortunately it wont. it is just showing an apple icon and a triangle with a exclamation point. when connected to a computer it does not...
There are many iPod error icons with exclamation marks
The Sad iPod icon (93936_4.gif ) usually means that the iPod can't access it's Hard Drive. I've seen that hitting the ipod on a soft surface occasionally fixes this. You may need to take the iPod for repair
The Folder Error icon (93936_1.gif) may mean the battery is low, the ipod needs to be reset, restored or needs a service
The Battery Icon (93936_2.gif) usually means the battery needs charging
93936_3.gif means a disk scan failed and will be repeated when the ipod is turned on or reset.
Try restoring it continuouly until it does (eventually worked for mine)
if it is anything else, your iPod may need repair.
Good Luck!
-AC
Jan 02, 2011 | Apple iPod mini 2nd generation MP3 Player
My i-pod wont charge through pc or wall power, it has a picture on the screen of an i-pod with a sad face in the screen and an exclamation sign in a triangle at the side, and just says apple...
That sounds like it crashed .. well go to apple support and download the ipod software.. try backing up all your data for this will cause total loss... reinstall the software...ope it waks.. i did it for a friend with a hanging ipod en it wakd..
Apr 28, 2010 | Apple iPod classic MP3 Player
I PUT LOCK CODE ON MY I POD AND FORGOT THE NUMBER HOW CAN I DELETE SO I CAN GET INTO MY I POD
n Windows
On the Windows side, you can also easily access your iPod's hidden files. First, right-click your iPod. Then, select Tools ® Folder Options. This takes you to Control Panel ® Folder Options. Select the View tab, as shown in Figure 3-17.
Figure 3-17. Showing your hidden files
Under "Hidden files and folders," change "Do not show hidden files and folders" to "Show hidden files and folders." Click Apply to All Folders, and now all the invisible files on your iPod will be visible
Now open my computer. open your ipod and then open the file labled ipod control. Find the file that says "LOCK" or something like that. DELETE IT. If you do not see the file, you can run a search for it. Just make sure that you are deleteing the file lock thats in your iPod and not anywhere else on your computer!
Dec 21, 2009 | Apple iPod nano
I pod 5th generation
i dont now
i havee
the same problem
:p
Aug 05, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 20 gig 4th gen
the conection from the battery to the ipod is bad , u need to have i looked at.(adapter)
Jan 17, 2008 | Apple iPod MA446LL/A MP3 Player
IPod does not charge
Search for 'The iPod battery Unplugged' it will probably help you diagnose the problem cheaper than apple will
Nov 27, 2007 | Audio Players & Recorders
I pod nano
Hold down menu and the centre button at the same time this should reset it.
Aug 17, 2006 | Apple iPod nano
Apple iPod MP3 Player Logo
209 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
