Question about Hotpoint Ultima WF865 Front Load Washer
Hotpoint Aquarius WF 430
Hi I have a problem with our washing machine.. It washs fine until it changes to spin.. And then it sounds as though a bearing of some sort has gone... Really loud and sounds as though it is about to explode... resulting in the machine coming to a halt with the rinse/hold and stop/start buttons flashing....Any ideas??
Rich
  • Hotpoint Master
  • 3,463 Answers
Best way to check if the main drum bearings have gone is to;
  1. Remove back panel of washer
  2. Remove drive belt.
  3. Spin drum by hand from the inside of the drum, if it feels rough, or is noisy and rumbling, then the main bearings have gone.
If there is no apparent noise, then you will have to investigate further.
If I can help further, pleas let me know.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Help to change bearings
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Apr 16, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF865 Front Load Washer Logo
217 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
