Question about Concept Slot Load Half-Din DVD Player Car Video Player
No sound I hooked up my DVD player everything works except I get no sound. I plugged the video in cable from the monitor to the video in on the player. I pluged in the audio out to the audio out on the player and get no sound. If you hold a speaker up to your ear you can barily hear anything. anyone have a fix?
    New Friend:
    Problem Solver:
  • 11 Answers
You must connect from audio out to audio in and. Video out to video in
Posted on Jan 10, 2018
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Hi.. I bought a used vehicle(2010 Ford F 150) which has a farenheit dvd-36 system I tried to play the dvd and the monitor, wire, remote....everything is working good. but, the only problem is that the
OK....Pull the dvd player out. Look to see if it has speaker wires coming off the back. If not, does it have rca plugs???? (red and white). if so then you are gonna need an amplifier to get sound. If it DOES hve speaker wires, chec to see if they are hooked up to the speakers in the vehicle.
Mar 13, 2012 | Farenheit DVD-36 Car DVD Player
Monitor says no signal and will not run a dvd
It could be a couple of things. If this monitor is hooked up to a computer, it could be a bad video card. A video card is easily fixed on a desktop, if you're using a laptop you're probably out of luck.
If it's hooked up to a DVD player, check that the cord to the monitor is hooked up properly (make sure the connection goes from the "Video Out" on the player to the "Video In" on the monitor and that all connections are tight, not barely hanging on). If that doesn't work, try a new cable.
This is probably insulting, but also make sure that the monitor is set to the right channel if it's multichannel. For example, if your DVD player is hooked up to HDMI 2, make sure the monitor is set to use HDMI 2 for signal.
If none of these work, it's time to find a tech-happy friend that can inspect everything visually. Hope that helps!
Feb 21, 2012 | Dell Computers & Internet
Hooking up a dvd player
If the three cables are yellow, white, and red, then the red doesn't need to be plugged in. The yellow is for the video signal, the white is for one sound signal, and the red is just for a second sound signal (not necessarily important). Everything will work fine if the red cable isn't plugged in at all.
Apr 01, 2010 | Emerson SpongeBob SquarePants TV
No digital audo from dvdld in
That's probably just for the video.  Plug in the L & R RCA plugs for the sound or just use an HDMI cable between your receiver and DVD player.  HDMI cables handle everything in one convenient cable.
Oct 25, 2009 | Sony STR-DE575 Receiver
Everything works except the radio. It appears
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Aug 07, 2009 | Jensen's VM9312 Car DVD Player
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
XOVISION CAR DVD PLAYER SOUND NO PICTURE
hook your brake line wire from stero to your ground wire. it needs to be grounded
Dec 30, 2008 | XO Vision XOD1735 Car DVD Player
Concept Slot Load Half-Din DVD Player Car Video Player Logo
60 people viewed this question
Top Concept Car Audio & Video Experts
Mike Duncan
Mike Duncan
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
