Question about HP LaserJet 2100 Printer
HP laserJet 2100 prints blank from manual tray
The printer works just fine as long as I am sending items to print from the paper tray. However, I am unable to print labels ~ specifically UPS labels. When I insert a label sheet in the manual tray, the printer grabs the sheet, but it doesn’t print. It comes back out completely blank and the orange light next to the triangle is flashing. So than I have to unplug the printer and plug it back in and push the reset (large) button in order to use it again and only from the paper tray. If I print any regular print job, regular paper in the manual tray it works fine. It used to print UPS label and now it won't. Any suggestions would be greatly appreciated.
  • pgutierre187 Oct 31, 2008
    its old. it doesn't have a usb port. and i tried reinstalling the drivers. No dice.
  • 102 Answers
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Posted on Oct 31, 2008
How to fix hp 2420 printing blanlk paper and then paper jam
Check the pick up rollers in the tray and look for signs of wear. Most likely this is your problem.
Apr 09, 2014 | HP LaserJet 2420 Printer
When i turn on printer, green light comes on. when i try to print with my hp laser jet 2100 printer, the orange light comes on. i have to press the start button (biggest round button), sometimes several...
Check the paper tray settings and make sure they are alinged with they type of paper you are using. (Ex. Letter) These settings have to be perfect in the tray so the printer knows what paper is in there. Usually when this happens the printed is asking you if you want to use the tray anyway and by pressing the button you are saying yes so it prints. Try loanding the manual tray with letter paper and see if the same thing happens.
Jan 17, 2011 | HP LaserJet 2100 Printer
My hp 2100 laserjet makes a sqeeking noise when it begains to print as if it is a roller, it works fine from the upper single feed with no noise please advise. Thanks
This could be caused by a worn and shiny paper seperator pad in the cassette tray 2.It sits at the front in the middle of the tray
Oct 12, 2009 | HP LaserJet 2100 Printer
LaserJEt 2100
Hi, try this.
Feed paper in tray 1.
If this works fine you better replace the roller and separation pad in tray 2.
To test where the swath of ink is comming from try this:
Feed papaer in tray 1.
Send a printjob. As soon as the paper is in the machine open the topcover.
Remove the cartridge and take out the paper carefully.
Check if the swath of ink is all over the side or only there where the paper was in the fuserunit.
If it is all over the side, the cartridge is defective. If its is only there where the paper was in the fuserunit you will have to replace the fuserunit.
Good luck,
Gerrit Jan
Jul 21, 2009 | HP LaserJet 2100 Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
Print Problem Go Light Flashing wont print till pushed
Sounds like its waiting for a manual feed. Check the paper you have in the tray and that the selectors on the tray are properly positioned. Once that os done, on the computer side hit the start ICON on your desktop, then control panel, then printers and faxes. Double click on your 2100 print driver to open it. Go into properties and make sure it says "automatic" for tray select. Hit the advanced key and check that it says letter or whatever paper size you have in the tray.
Verify the other settings and then save it.
That should solve your issue.
Aug 07, 2008 | HP LaserJet 2100 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 2100 Printer Logo
296 people viewed this question
Seeker5211
Seeker5211
