Please can someone help me!! We purchased 1 year agao a Viesmann Vitodens 100 Combi Boiler and have had major problems with the flow switch sticking. We have had 3 sub contractors come out and replace the flow switch and a Viesmann engineer come out very recently blaming the water for the problem with the flow switch!! Their are around 70% of combi boilers sold throughout the uk and water is a big part of a boiler working, we also found out that we should have a filter fitted to the main supply to prevent any debris/particles getting in to cause the flow switch to stick. My view on this quite frankly is why on earth manufacture a boiler so highly sensitive to grit or particles, I also asked the question of the possibility of the model being faulty but was told definately not its a water issue. I would like to hear from someone who has an unbiased view Regards Simon Cooper
    Novelist:
  • 124 Answers
I am pleased to suggest that you try to following. i would wager that the switch is installed in the horizontal position. try replumbing so that the switch or valve is verticle to the ground. . that way particles will settle down with water flow and not be eating up the gaskets on the valve. in other words flow side to side leaves debris in the valve when it seats. . installed in a vertical position the valve flushes itself as it seats. good luck let me know what happens.
Posted on Nov 01, 2008
I have an Alpha 240E combi boiler; if two taps are turned on at the same time or say the washing machine is running and someone fills the kettle it trips. Why please? The water pressure is slightly above...
Water flow combi will only pass so much , unless there is a blockage in the water section on your boiler, or water inlet tap is not fully open .
But some combis do have poor flow through the heat exchanger .
Jan 28, 2013 | Desa International GWP20T GLOWARM Wall...
Britony 80 combi boiler G31 propane, gas flow rate =0.124877 cubic meters per hour, inlet pressure 37mbar, room sealed flu Manufactures recommended Co2 & NFGT unknown, cold water from hot tap when...
You gave a good description of the boiler--
now we need to hear the clues you have observed, as it fires (or fails to fire-- or what?)
Or as the water flow-- or doesn't flow?
As the cold water enters-- what does the flame do?
And does the flow rate reduce as the flow gets to the divert er valve?
How old is the boiler?-- and have we been using HARD water?
(Any water softener in the circuit to remove calcium and magnesium, etc.?)
Do you suspect a scaling problem in the interior parts?
If so-- can you circuit an acid thru the innards, to clean up the scale?
Please comment on what happens when water and gas flow-- so we can help you get to the next step.
Mack B
Jan 17, 2011 | Heating & Cooling
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
I have a vitodens 100-w combi boiler and tried to turn the heating on just to give it a working as was advised. However, I have no heat coming to my radiators. The boilers seems to be working as my hot...
Here's the deal: If your Vitodens 100 has outdoor temperature sensing capability, either built in or via external aftermarket control such as Tekmar or other, and the temperature outside is above warm weather shut down (WWSD), then the boiler will not operate for space heating, but will operate to make Domestic Hot Water (DHW) only. Generally speaking WWSD is facoty set at 20*C, since this is normal room temperature so the boiler will not need to operate at temperatures above this number as it is warm enough outdoors to heat the house to comfortable levels.
If your Vitodens 100 does not have outdoor temperature sensing capability then you should check to see if your room thermostats are operational and calling for heat since the boiler is only responding to this on-off control based on room temperature. (turn up your room thermostats)
In both cases you need to make sure that your heating system's distribution pump and zone valves are operating correctly.
In any case you should be calling a heating contractor if you suspect that there is a problem with your boiler and/or heating system.
Good luck.
Aug 07, 2008 | Heating & Cooling
Combi bolier problem
either the h/w flow switch or diaphram reqs replacement or the secondary heat ex or (calorifier) is blocked and prevents the heat from leaving the biler to hget to he taps- the heat starts ok but backs up to the boiler very quickly causing it to shut down
Feb 20, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
313 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
