Question about Canon CLC 1150 Color Copier
Where is the ATR Sensor?
I have an Canon 1150 and I am getting the E020 0481 error. I noticed some folks have said clean the ATR sensor. But where is the ATR sensor located???
Error 20 please chek toner
Posted on Oct 31, 2008
E020 0481 error
Posted on Nov 13, 2008
My canon image runner advance c2030 has an error code E000020-050 what can be the problem?
Dear
Its the failure of ATR patch or its sensor. If you have knowledge you can proceed to check the ATR sensor Shutter if opened.Check window of the patch sensor for soiled clean it with dry cloth.Check the visibility and density of the patches on the ITB if abnormal do ..COPIER -FUNCTION-PART-CKECK-SL02 to move SL02. Check the Y drum unit cross check with good Y drum unit.
If still problem persists it need the attention of trained service engineer at site.
Thanks.
Jan 29, 2015 | Canon Office Equipment & Supplies
E000022-000 ERROR CODE IN C2020L
its an error code from ATR sensor / abnormal detected patch reading vaue to reset it clean the toner hopper sensor and enter the service mode>clear>eng>trans>ok then turn OFF and ON
Jan 16, 2015 | Canon Office Equipment & Supplies
Hello sir i am getting error on Canon irc3170 errror code 0020-01a8 ..... it was working fine but when i filled yellow and magenta tone since then i am getting this error code i think i ned to clean atr...
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XXA8= In ATR control, the detected T/D ratio is upper than its upper limit (13%) 3 times
in succession.
-01A8 = YELLOW ISSUE
Check on toner leak from toner buffer in the developing unit, Replace the ATR sensor
imageRUNNER C3100 / C3170
Jan 09, 2018 | Canon ImageRunner C-3170I Copier
I get problem in my printer CANON IRC3580i the erorr code is: E000020-0012, so any body can help me?
1. Check to see if the ATR shutter comes off; if so, re-fit it.
2. Wipe the ATR sensor window with a damp cotton cloth.
3. If the symptom still occurs, replace the ATR sensor with a new one. 0012 is for the cyan drum
Sep 08, 2010 | Canon imageRUNNER C3200 Copier
I have a Canon IR C3220, and i started off with the yellow drum error code, which i just replaced, and now I'm getting error code E000020-0125. Can you please help me?
It is possible the front door plastic door interlock for the SALT sensor shutter is broken or not in place, (see picture below). If the shutter is not actuated by the interlock, the SALT sensor will error out when trying to perform ATR measurement resulting in an E020. Sub codes will be related to yellow ATR measurementsince it is the first color laid down on the ITB for ATR measurement.
Sep 07, 2010 | Canon imageRUNNER C3200 Copier
Error codes 000070-001 and 00020-081 for iRC3180i
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
X93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
and,
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
...so, I pressume that something is broken, because you are getting these two error codes... call service, or write on emma.servis@gmail.com for service manual.
Hope that helps!
Aug 10, 2010 | Canon Office Equipment & Supplies
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
data corruption.
corruption.
out.
the developing unit
sensor
succession.
the developing unit
XX93 A computation result of patch reading in
succession.
sensor
ATR sensor
ATR sensor
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
Apr 20, 2010 | Canon imageRUNNER C3200 Copier
E020 sub code 0481
ATR Error (E020-XXXX) Display due to Dirt on ATR Sensor Window
Cause
The waste toner may adhere on the ATR sensor window or the sensor shutter. As a result of that, it may be faultily detected as ATR sensor fault and trigger the ATR sensor error (E020-XXXX).
The detail codes (xxxx) are as follow: XXA0, XXA2, XXA8, XXA9, XXC0, XX10, XX11, XXDA.
Filed Measure
Clean the ATR sensor window and the ATR sensor shutter with the following procedure. 1) Remove the ATR sensor from the main body. 2) Press the plunger [1] of the ATR sensor lever solenoid in the direction of the arrow. 3) Clean the ATR sensor window [2] and the ATR sensor shutter [3] with lint-free paper [4].
Pls rate thanks!!!!!!!!! dont forget testimonial mate.
Oct 17, 2009 | Canon CLC 1150 Color Copier
I have a Canon CLC1140 that I getting an E020 0481 error on. I have cleaned and replaced the starter toner in the black developer and it worked for about 30 minutes and the error came back. Can you assist...
How old is the drum? The ATR sensor may not be reading correctly, due to a older drum and can't get a correct reading. Was the problem there before you replaced the Black developer? Also, have you tried to replace the ATR sensor yet? Try those few things and get back to us.... Good Luck
Aug 04, 2009 | Office Equipment & Supplies
Canon 1150 E020 04E0 Code error
change all 4 developers plus blow clean both developer sensors you can find these sensors next to the black developer assy it has one screw
Jul 23, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
614 people viewed this question
old marine
old marine
