Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
Cd drive (or whatever the thing you put your cds in is called)
I have a problem. I put a cd into the cd drive, but when i wanted to retrieve it, it wouldn't come out. I pressed the eject button and nothing happened.You know how there's a flap that opens before the cd holder comes out and reveals the cd, well that wouldn't open either. Please Help!!!
  • 488 Answers
There will be a tiny hole below the flap..use a needle and push on it while pressing the eject button..it should open after a few tries! have the same problem on my optiplex 210L dell..hope it helps!
Posted on Oct 31, 2008
  • 84 Answers
The is a small hole next to the tray
Find a paper clip and gently puch the release the tray should open
LB
A few months ago...i had a cd stuck in my 2004 malibu cd player. I was able to remove the cd with tweezers, but now when I try to put a new cd in, whatever the thing is called that grabs the cd, won't...
Turn off the car (ignition switch off), pull the fuse for the radio, start the car (ignition switch to run), and put the fuse back in. Should completely reset the radio and let you eject the CD if it doesn't automatically eject it when the radio powers up again. Even with both the radio and the car turned "off" the radio still has power running to it, and it really isn't off, but in an extremely low power "sleep" mode (it's how the clock keeps running among a few other things).
The radio fuse should be a 10 Amp blade type fuse under the panel on the right side of the center console down in the right front passenger foot well. The panel pulls off and has a fuse diagram on the inside of the panel. Recommend using a flashlight.
This 'reading text" lockup is a known issue for that radio for CDs that have a large amount of "CD-Text" on them (an extension of the audio CD standard) in addition to the audio tracks. The CD deck and radio software were designed to handle a few kilobytes, but newer CDs often have more, much more, and it overloads the radio software trying to read it as it cannot store it all, and it locks up the deck. There was a radio software update fix for this that was rolled out to dealerships when these vehicles were under warranty, but apparently your radio was never reflashed or exchanged for one with the software update. I recommend seeing a Chevy dealership and asking to talk to the service manager about getting the radio updated or exchanged with the software fix . . . and they should do this without any charge as it was a latent defect in the radio software from day one . . . don't let them tell you the deck is broken . . . the problem is deck lockup when trying to read audio CDs with large amounts of CD-text on them because of a latent software defect in the radio (that was there from the day the radio was made). Only a few music CDs seem to have this problem, but it's a huge one with audio book CDs (books on CD) that have usually have many more audio tracks and much more CD-text compared to music CDs.
If you cannot get satisfaction after visiting two or three dealers, call Chevy directly and take up the issue with them . . . and tell them there should have been a recall to fix it while the vehicle was under warranty . . . but there wasn't (I believe there is a service bulletin though).
Feb 26, 2011 | 2004 Chevrolet Malibu
Solve a jammed cd problem
Usually if you remove the cover you can access the area where the CDs are. You may have to remove the cover from the drive also. Let me know how this works out.
hardrocko
Jan 31, 2010 | Onkyo DX-RD511 CD Player
Mac Book Pro won't burn cds - spits out the cd
try a real music cd to check drive.
some blanks are no good try another brand or try a dvd to check drive
if it plays real and records on dvd then drive is ok
Sep 12, 2009 | Apple MacBook Pro Laptop Computer with...
How easy is it to change a cd drive to a floppy on a dell latitude xpi running win 95?
It is very easy if you buy the floppy drive separately and connect it via one of your USB ports. But who wants to change a CD to a floppy? It's like changing a exchanging a motorcycle for a bicycle. CDs are newer technology....unless you have old data you want to retrieve.
Aug 13, 2009 | Dell Latitude XPi Series Laptop Floppy...
Want to crash this computer
1. Make a full backup of your data on cd/dvd, an other hard disk or whatever you have.
2. If you have recevery disks, put the first one into the drive, turn off the power and restart. Press spacebar to boot from cd when asked for. Follow instructions.
3. If you dont have recovery CDs, use your Windows installation disk and follow the rest of procedure #2. You should choose to delete all partition then install on empty space.
Mar 27, 2009 | Dell Dimension 2400 PC Desktop
2001 Lincoln LS Can't get the CDs to eject
my problem is with the alpine system. it only ejects when cold. if tried when hot it jams and wont play cds or release until cold again. i removed the panel above the radio and place an icepac on the radio and after a while it starts spitting out cds
Jul 22, 2008 | Panasonic CQ-DPX33 CD Changer
Cd-writter problem
first u buy a new lens cleaner for ur pc and run it on ur cd drive den ry to burn a new disk and see it burn or not if same prolem again comes then it is sure dat ur lense sensitivity gets low....
now it is not capable of writing ny thing only capable od read various cds......
if r havin more problems wid ur writer ask me for more solution..
Jun 19, 2008 | LG GSA-4160BI (GSA4160BK) DVD±RW Dual...
CD ROM
1.Try updating your firmware by contacting Dell technical support.
2.Try Calling a Local Technician To check for loose connection or Check it your self.
3.Reset your BIOS Settiongs
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Dell Dimension 8200 PC Desktop
Can't read, burn cds
have you tried different cds? or just 1 same cd?
Oct 19, 2007 | Compaq Presario 5000 PC Desktop
Buring CDs
Install a software for recording and write with Nero as a data cd.
Oct 02, 2007 | Toshiba ZA2055P08 - Satellite 1800 24X...
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
