Question about HP LaserJet 2420 Printer
Error code when i start my laserjet printer 2420 it shows 53.07error and show mesage turn of printer and turn on
  • 94 Answers
This is a ram dimm error try changing dimm(s) to other slots(s) please ask for more info if required
Posted on Oct 31, 2008
Trying to print using my new hp Laserjet 2420 yet being told error printing. The printer shows tray 2 is empty yet it has some papers. Is there a way to only use tray 1 if the tray 2 cannot operate...
Tray 2 paper senor not sensing the paper either it may dusty,failed or sensor flag mis placed.. verify where is the fault..Location: remove tray2 cassette, under you can observe the paper sensing flag..
Aug 30, 2011 | HP LaserJet 2420 Printer
I have a HP Laserjet 2420 and show error code 41.03.00
Un expected paper too lengh, check papers are loading one by one or more then one at a time loading in side?..If multi papers are loading, replave separation padClean all paper path sensors..
Aug 19, 2011 | HP LaserJet 2420 Printer
On powerup the HP Laserjet 2420 display shows 000MB ********** ******************* Bad boot DIMM?
I think you have a bad memory module, or a bad system board, did it happened after a power loss or power surg??? (common for these printers)
Have you tried to reset it to factory default (according to service manual)
Mar 14, 2011 | HP LaserJet 2420 Printer
LJ 2420 IN 49.FF95 SERVICE ERROR SHOWING PLS. CONFORME WHAT IS ISSUE IN PRINTER?
remove the network card at the back, re-insert or replace it...
Jan 21, 2011 | HP LaserJet 2420 Printer
My hp 2420 pcl 5e STOP PRINTING SUDDENLY. & showing me (FUSER ERROR) TELL ME WHAT CAN I DO TO SOLVE THIS PROBLEM I TURN IT OFF AND BACK ON 3 TIMES BUT PROBLEM IS STILL THE SAME.
Hi
Problem either fuser faulty or dc controller card faulty first check for faulty fuser & after then dc controller fuse of fuser.
Thanks
Sep 25, 2010 | HP LaserJet 2420 Printer
My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Jun 19, 2009 | HP LaserJet 2420 Printer
HP 2420 Issue
Print a configuration page found under the info menu on the printer. Make sure that under options it shows the network card as being an installed otion (it will show enven if its a built-in embedded card) If it doesn't show you have a bad jetdirect card. If it does show make sure the IP address, Subnetmask and Default Gateway listed on the page match that shown on your SERVER & WORKSTATIONS.
If the card info on the config page reads 0000 then you will need to reconfigure the card through the menu.
If you are using a 615N Jetdirect card in the printer and it doesn't list on the config page it's most likely a bad card as they have been dying regularly. If and only if it's a HP 615N card, jump on HP's support chat at HP.com and go through the on-line chat. If your persistent and insist, they will replace the card for free. You will have to be persistent though and tell them to look up the service note that authorizes after warranty replacement. They know it's their but unless your persistent they will play dumb try and charge you. Hope that helps you.
Jul 11, 2008 | HP LaserJet 2420 Printer
Hp laserjet printer problem
Try to reinstall your software, if it is show the error again replaced the memory and then try to power on the printer.
Jun 16, 2008 | HP LaserJet 2420 Printer
Hp 2420 not starting up
Hi there you both may have the power board blown the only way to check is plug in a new power cord if this doesn't work then will have to find a repair station.
Hope the cable works though
Please rate me
Cheers J
Sep 15, 2006 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
107 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
