Question about Kenwood KDC-135 CD Player
Ocer When i turn the unit on OCER appears nothing else works...
  • tonysaurman Nov 14, 2008
    I also have a KDC-135 and "ocer" apears and nothing else works. I need a solution.
  • 3 Answers
Try disconnecting the negative battery terminal for like 20 seconds then hook it back up and try to turn the radio back on
Posted on May 12, 2009
    Sergeant:
  • 324 Answers
Remove your postive battery cabelf or 10 mins, this will clear all codes and defaults.
Posted on Nov 26, 2008
I have model kdc-138 & it show "ocer" on the screen & nothing works-radio or cd player...help???
Please check this message. If it is DCER, not OCER, you have a short-circuit in the speaker wiring or a wire is touching the vehicle chassis. Until the wire is fixed (insulated or replaced), the receiver will remain in the Protection mode. This keeps the short from permanently damaging the unit. After you insulate all of the wires, press the RESET button, to the left of and below the volume knob.
If the error persists, then you need to have the receiver professionally serviced. The short is probably inside the receiver itself.
I hope this helps. The troubleshooting guide is on page 18 of the manual. It is available from Kenwood here: http://manual.kenwood.com/files/B64-3898-00_00_KW.pdf . The image of the reset button position is on page 3.
Sep 17, 2015 | Kenwood Car Audio & Video
My system just stop working and its only blinking ocer
OCER indicates that the unitis in protect mode. First press the reset button (tiny pinhole button). If the unit comes back on saying OCER then most likely there is a short or a grounding problem with the speakers or speaker wiring. Disconnect all speakers and press reset again. If OCER still shows up the unit needs service. If not, connect each speaker once at a time until the unit comes back in OCER to narrow down the location of the unwanted DC signal.
Apr 02, 2010 | Kenwood KDC-MP235 CD Player
The screen keeps showing OCER.
It's in protect mode. If you have a reset button, press it, it should be next to the SRC button(very small hole, need a toothpick to press) if it works you're ok. if not unplug speakers one at a time to see if you have a short. good luck
Sep 09, 2009 | Kenwood KDC-138 FM / AM Receiver
OCER
remove the positive battery cablef or 10 mins, this will clear any codes or defaults in the stereo.
Nov 23, 2008 | Kenwood KDC-135 CD Player
Code OCER AND WILL NOT PLAY
Hi, This also happened to me, and what I did was, I reset the radio and wala it worked fine. Hope this works for you.
:OCER
Ive had this problem lots of times I cant find the underlying cause but for a quick fix just hit the little reset button on the bottom left corner. Im still trying to find a way to stop it from constantly happening
Sep 05, 2008 | Kenwood KDC-138 FM / AM Receiver
DCER error (people spell it "ocer"
Problem is the internal amp chip, if it was a speaker problem or shory they flash Protect.
OCER oe DCER is the amp chip Part #KKZ10 REF# ic5
May 15, 2008 | Kenwood KDC-135 CD Player
Kenwood KDC-135 CD Player Logo
480 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
