Question about Sony STR-DE595 Receiver
Buzz sound when i hook my laptop up
I hook my laptop up to the receiver using a "y" cord from the headphone port on my laptop, and it makes a kinda "buzzing" noise in the speakers. If i try to play music it plays faintly but the buzz is too loud. I dont think its the laptop because i put it on another receiver and it worked fine, i tried hooking it to different inputs(cd,phono,video2..) but same issue. It did work for a few years until last week so im assuming something is wrong with the receiver. let me know if there is anything i can try before takin git in. thanks
  • 28 Answers
How many years have you had this laptop? Sad to say, if it's many years, time to replace as that would be cheaper.
Posted on Apr 29, 2017
KaeZoo
  • 156 Answers
SOURCE: speaker issues
Disconnect whatever wire is connected to the blue wire behind your head unit. Re-connect it to the blue/white wire, instead.
Posted on Jun 21, 2007
whitesox
  • 64 Answers
SOURCE: PS2 MAKES BUZZING NOISE
Between the ps2 and the TV, loop the cable around a metal rod or post of some sort. This should disrupt the interference you are getting which is caused by the electricities frequency! Hope this helps!
Posted on Jul 26, 2007
SOURCE: STR-DE845
I have this receiver and my audio is a optic cable to my cable box. When I play a dvd my sound works great my I can't watch cable. There is no sound. It has always worked untill I finished a movie and tried to switch to cable and then there was no sound. Can anyone help?
Posted on Dec 28, 2007
  • 53 Answers
SOURCE: psp making funny buzz noise and not reading umd disks.
Try a different UMD, it might be scratched. If not, take a soft cloth, and clean the lens. Look on google to see where the lens are located.
Posted on Jan 14, 2009
  • 13 Answers
SOURCE: Playstation 2 will not display nor play sound
try checking the three coloured plugs in each end of ps2 and tv you noe the red yellow and white plugs make sure they are in the rite order
Posted on Apr 24, 2009
Cant get sound from laptop to tv
Just to verify...you've made sure that your headphones jack will play audio in lets say, some headphones, or a set of computer speakers?
However, your T.V. may not recognize audio when using VGA. I say this because if you look at the hook-ups on your T.V., you notice that most sections contain audio and video together, not seperate. If the port is available on your computer, trying using HDMI, the single cord for HDMI carries both sound and video. One last thing you can try with your current set up is find a set of the red and white rca hookups that are independent of any other grouping, in other words excluding the yellow video or any other connections. If you're T.V. wont play the sound in that, then either your headphones jack is messed up or the T.V. just wont recognize it while using VGA.
Nov 21, 2011 | Computers & Internet
I have an Emerson 42in flat screen lcd. It has 3 hdmi ports, a pc port, etc. What I need is an audio out port and the only audio out port is the Digital audio out. My ps3 and xbox 360 are hooked up through...
If you have a home theatre system, most receivers have a digital audio input that you can use and hook that up to the digital audtio output on your TV. I have the same TV, and this is how I am doing it.
The other option is to get a new receiver that supports HDMI, and feed you HDMI into the receiver and then use the HDMI out from the receiver to the TV.
These are about the only options you have.
Dec 09, 2010 | Audio Players & Recorders
PA3144U-1ETC Consumer Headphones: get a buzz in my headphones for my laptop...
it could be that you only get this when the power cord is connected, if so that is your problem, its an earth issue with the power supply.
May 06, 2010 | Toshiba PA3144U-1ETC Consumer Headphones
I have a macbook and want to hook up to my dynex 24 inch tv. I am successful using (mini dvi to dvi to hdmi) connection to the tv receiving great video. My problem is that I have no been able to get audio...
Your mac would have to have a fully hd compliant mini port. To be honest I havent even checked to see if any do. Then you would want to get a mini video port to HDMI adapter. If you don't have one of the newer Intel mac then chances are you cant do sound through that port, which is what your tv is looking for on the hdmi port.
Easiest solution is to hook your headphone port on your laptop to a stereo or some decent computer speakers, which usually sound better than tv speakers anyway.
Jan 08, 2010 | Apple Computers & Internet
Gateway ML6732 Sound Malfuction
sOUNDS LIKE YOU HAVE DONE SOME SERIOUS DAMAGE TO YOUR LAPTOP
Jan 02, 2010 | HP Pavilion dv9000z Notebook
Buzzing sound on TV, Bad Picture...
You have a Genesis 1. Make sure that you are using the correct power supply; the first models use a different voltage than the second or third models.
Sep 30, 2009 | Sega Genesis Console
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Laptop to TV connection but no audio
what kinda connection did you made?? what kinda cord did you use....anyway...it usually works that way..you can get image on TV ..by setting the image card driver ...but the sound bust be connected separately ...if your TV has a input plug for sound...just take a proper cable ...and get signal from the green out of the computer and plug it into the input of the tv ...this way you will have sound comming from the TV speakers and access on the volume with its remote control ...but no matter what kinda plug u used for the connection with the tv ...you will not get eny thing more than image..
so...if your TV doesnt support sound plug in just attach some speachers ...
Jun 14, 2009 | Acer Computers & Internet
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Sep 14, 2006 | Marantz SR-5600 Receiver
Sony STR-DE595 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
