Question about Intel 845GE Motherboard
USB Problem recently my usb in board failed. in device manager also it is not displaying like unknown device also.  how can i solve this problem
  • Anonymous Dec 04, 2008
    recently my usb in board failed. in device manager also it is not displaying like unknown device also. how can i...
  • 94 Answers
Reinstall usb driver from mobo disk or download from manufaturers web site
Posted on Oct 31, 2008
USB devices failed enumeration
If they are required, toshiba will have them on their web site.
Apr 17, 2014 | Toshiba Computers & Internet
I have a thoshiba satelite a100 laptop my problem is usb device is not working i format the laptop and then install windows xp sp3 but not solve this problem i conect any usb device then erormessege is...
To work around the above issues, one of the below solutions could prove helpful:usb-device-not-recognized.jpg
  • Unsecure or Loose Connection
    Unplug the presently connected USB device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a USB device.
  • Scan for Hardware Changes in Device Manager
    Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the USB device.
  • USB Hub Power Management
    Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps; Click Start, and then click Run. Type devmgmt.msc in the popup box, and then click Ok. Expand the Universal Serial Bus Controllers' node, and then follow these steps for each USB Root Hub that is listed.
    1. Right-click the USB Root Hub and then click Properties.
    2. Click the Power Management tab.
    3. Click to clear the Allow the computer to turn off this device to save power check box, and then click Ok.
    Note: If you perform the following p
      Unplug the presently connected usb device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a usb device.
      Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the usb device.
    • usb Power Management
      Note: If you perform the following procedure on a laptop computer, you may reduce the battery life.
    Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert.
Mar 28, 2011 | Computers & Internet
My laptop with windows 7 all of a sudden cannot detect any usb? indication at device manager, usb host controller, there's an unknown device??can u help me what to do?
hi.
the Driver of USB Controller is deleted (by a virus or something like that)
and you need to install some drivers.
so put the motherboard driver Disk in your drive and try to update the unknown device in your Device manager
or install complete drivers of the Disk.
Jan 29, 2011 | Microsoft Computers & Internet
I have a toshiba satellite l355. Recently 2 of the
It all depends on the device you're connecting. If it a flashdrive, and get the same error, you might wanna uninstall the USB under device manager and re install it back.
Hope this helps.
Dec 19, 2009 | Toshiba Computers & Internet
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
Apr 11, 2009 | Nokia 6500 Slide Cellular Phone
Problem yet not solved i.e usb not detected on any port and without usb installed, an unknown device is indicate,
Is the USB showing yellow mark on Device Manager entries. When you connect any device to USB does it show any device??
If not, then it might be the USB chips failure on your MoBo and need to replace.
Otherwise, go to Intel support site and download all the updated drivers for your MoBo.
http://downloadcenter.intel.com/
Feb 24, 2009 | Intel Motherboard
MY COMPUTER CANNOT DETECT MY USB
open control panel..go to system..device manager..usb is usually at the bottom..remove them all, and then scan for hardware changes..should do the trick..
Oct 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Hp laserjet 1020 ( usb device not recognized )!?
I wish that there was a simple, single answer for this. There's only one thing more distressing - no device recognition at all. Here are the most likely culprits:
* The USB device or the USB adapter requires it's own power source. If your USB device or adapter came with an AC power "brick", try connecting it.
* Here's a likely one - the front USB ports on your PC case may be misconnected. I've seen them that way from the factory. It's a good idea to check the connections against specifications. The standard order of connection is Red, White, Green, Black. No more than 4 wires per USB bank are needed.
* Defective device. Do not assume that all PC components work correctly out of the box. I've seen many new USB devices that do not work. If you can, try the device on another PC.
* All drivers are not installed. Some devices will require installing the driver package before plugging in the device. Some devices will also require basic USB files from the Windows CD before the unit will function. The general rule is to always follow installation directions precisely and to have the Windows CD ready.
I will now discuss how to address an unknown device problem which is caused by a driver deficiency.
1. Try to update the unknown device driver from within Device Manager. First try letting Windows search for one. If that fails, go back and choose "Select from a list" and then "Have disk". Browse to the device CD and look for the appropriate Windows folder there. Try browsing to the Windows CD (Win9x folder or i386 folder). Lastly, try updated drivers from the manufacturer's web site.
2. Try uninstalling the unknown device, unplugging the device and rebooting. Replug when back in Windows.
3. Be certain that you have the correct drivers! You may have gotten the wrong CD or a CD with drivers for more than one device on it.
4. Cleaning up in Safe Mode may be necessary. Unplug all USB devices. Reboot the PC. To enter Safe Mode, press the F8 key repeatedly while restarting the PC. Timing is important. Try to press quickly before the Windows logo screen appears. Pressing and holding the CTRL key may work too. Choose Safe Mode and open Device Manager. In Windows 2000 and XP, click View > Show hidden devices. Now locate all USB devices, HID (Human Interface Devices), USB drives and controllers/hubs. Remove all and save the USB Host Controllers for last. When done, restart and replug USB devices one at a time.
Just remember that you are entitled to support from the device maker. If you can't get help, do not hesitate to return the device. Some manufacturers only seem to respond to lost business. It's a shame, but it's true. Send them a message - that you won't accept shoddy goods or lackluster support.
Mar 26, 2008 | HP Photosmart 3210 Printer
Intel 845GE Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
