Question about Dryers
HOTPOINT TUMBLE DRYER BLOWS THE TRIP JUST A FEW MINUTES AFTER BEING SWITCHED ON
  • Debztar Mar 04, 2009
    My Hotpoint condenser dryer works for 5 minutes and then it trips the electric.
  • 958 Answers
Could be a short in the heating element.
needs a current meter to further help you. the tool the we call clamp meter that would measure current being drawn by the equipment.
because we might end up replacing a good heating element and the problem is the circuit breaker.
circuit breakers could also become faulty and would trip off even with a good unit plugged unto it. no longer calibrated.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
My Hotpoint tvf770 starts but does not appear to heat and it stops after a few minutes. I have checked the filter and exhaust tube for blockages, both clear.
Suspect a broken/burned off wire to the heater element, or 'open circuit' of the heater element, or thermostat fault
Oct 15, 2013 | Hotpoint TVF770 Tumble Dryer
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Tumble dryer blows main fuse
check fuse rate on dryer if same rate. check dryer for amps if pulling to many will blow fuse, if dryer is ok check from plug in to fuse.
Jul 29, 2012 | Hotpoint Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
Dryer wont heat up
There could be a number of reasons why your dryer is not heating.
1) The element may be faulty
2) A thermostat or thermistor could be faulty or need resetting (if you have one with a reset button) You would need to check your hand book for this info.
3) you could have a wiring fault or lose terminal.
4) If you have a dryer with a revers tumble (one that goes in the opposit direction for a few minutes before continueing) on some models this incorperates a revers timer that works off the main timer and when it is in revers tumble the heater is switched off. If the timer is faulty it would keep the heater permanently switched off.
For more Hotpoint help click on link
Mar 18, 2010 | Roper Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
The tumble dryer trips out
It sound as though it is overheating.
This may be caused by a reduction of air flowing through the machine.
Check all the filters and the out pipe for blockages that would restrict the air flow.
Dec 14, 2009 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
