Question about Canon DC100 DVD Camcorder
Canon DC 100
The camera will only turn on when the charger is attached. When I plug the charger in, the red light flashed continuously.
    Problem Solver:
  • 10 Answers
Check your battery or change it..battery output should have 7.8v.
Posted on Dec 09, 2008
How do I know it's charging
if you can get your hands on a volt meter attach the meter to the charger clamps, red to red and black to black, turn the volt meter to DC volts (20V scale on most) and turn on the charger. You should be reading at least 12V.
Dec 05, 2013 | JUMP START SYSTEM
I have a jazz hdv188 i just bought from a friend who didnt have a charger and i have a motorolla phone charger, the charger turns the light on to red blinks for a few seconds then shines red continually, I...
according to the manual guide, you cannot use another recharging, only the recharge that came with the camera, because you can get a problem on the screen.
you have to use this ADAPTER>
Sunny* SWITCHING ADAPTER
MODEL: SYS1196-0605-W2
PART NO: SYS1196-0505-W2-C
INPUT: 100-240V-0.3A MAX 50-60Hz
OUTPUT: +5V_-_1.0A
OUTPUT POWER: 5W MAX.
Nov 13, 2010 | Jazz HDV-188 Camcorder
My digipower travel charger flashs red when the
For mulitply camera battery charger ,there are many special online shop for you to select on the internet.
May 17, 2010 | Digipower Travel Charger for Select...
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Monitor for recording
attached the jack wire from the camcorder video output and the red and yellow wire goes to the tv video input.select the AV from your tv.good luck.
Sep 28, 2008 | Canon DC100 DVD Camcorder
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Canon DC100 DVD Camcorder Logo
106 people viewed this question
Top Canon Video Cameras Experts
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
