Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA big Screen
I Have a bow in my picture and the image is 3D. I have an HD52W59 model RCA big screen, I read that it is either the convergence board or the convergence power supply. where is it located in the TV and how can i tell which one is the problem? I don't want to buy both if only one is the problem, it is expensive for either part.
Hope you can help!
  • Anonymous Nov 11, 2008
    I am having the same problem with my tv it is an RCA R56WH78 is the part number the same and where do I buy it.
    I have the same problem on my R56Wh78 RCA projection tv will the same part work for mine and where do I find it
    Genius:
  • 1,030 Answers
Convegence problems are so common on these sets. The bowing picture indicates to me that you have lost complete convergence. Now the first question that i always ask is do you have the convergence option under setup in the customer menu. If you do not then i say congratulations this is a simple inexpensive repair if you can solder a component. this is known as the fl231 problem and i have a article relating to the problem under my profile in tips and tricks section. that goes into detail on how to repair this problem.. If you do have the convergence option then we wil have to go further into troubleshooting. there are three possible cuircits that effect this.. if you do have convergence. try autoconvergence option and see how far it gets. let me know how it goess.
Posted on Oct 31, 2008
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Nov 22, 2012 | RCA HD52W59 HDTV Projection Television
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
HI i have an RCA HD52W59 and the picture looks 3D, I can use the manual convergence but when tv is shut off and turned back on it goes back to the 3D look and the auto convergence does not work - the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
CONVERGENCE ISSUE *UPDATED* RCA HD52W63D
Convergence Power supply board. In the television above the cuircit boards there are two curcit boards that sort of hang above. the one on the right is the convergence amplifer board(has metal fin like heat sinks).. The one on the left is the convergence power board. Since you have options and no control, bowing picture. this would be my first choice. Now it still may have convergence amplier trouble. To get these boards you will have to get the entire model with suffix ext. it will be like d52w20...yx1 yx2 or something like that. in small leter on the model sticker on back
l
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 Wavy lines
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
