Question about Refrigerators
My fridge thinks its a freezer. Entire contents are frozen. I cannot get to the back of the fridge or even see the make as it is integrated with my kitchen units. I have set thermostat to lowest point but no change.
  • 120 Answers
Well repl the thermostat if you dont know how i suggest a tech to do it thank you
Posted on Oct 31, 2008
Freezer working ok but the fridge isn't
many times it will be the air flow from freezer section to the fridge has failed have even heard that some makes this is not fixable even buy the repairmen
Jul 12, 2015 | Refrigerators
Tip
Defrosting Tips for Your Fridge & Freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Defrosting fridge/freezers is much easier with a two-control model. That way, you can use the fridge to keep foodstuffs frozen while you deal with the freezer.
Are you thinking of defrosting method for your freezer or fridge? Then check this out.
Always switch off and unplug the freezer before cleaning or defrosting.
Load the contents of your freezer into large dustbin bags and cover the bags with a duvet or blanket. The food should stay frozen for several hours. But use a cool box for ice cream or soup which melts quickly.
After defrosting, wash fridges and freezers with a solution of two teaspoons of bicarbonate of soda to 1 liter (2 pints) of warm water-it removes lingering smells.
Rub the inside of your freezer with glycerine, available from chemists, after it has defrosted. When you next have to defrost it, the ice will come away from the sides more easily.
Use a wet/dry vacuum cleaner to **** up any water left on the floor.
If you do not like defrosting, you can always pay more for a frost-free freezer which never needs it. www.victorwod1234.blogspot.com
on Apr 05, 2010 | Refrigerators
How to set temperature on built-in freezer that is not part of a fridge
Well start by defrosting it.
Empty out the contents and put the contents in a cooler and then switch it off. You may need to switch it off at the electrical control panel by flipping the circuit breaker.
Once you have turned it off, use hot water to help remove the ice. Have plenty of old towels around for this as water will get spilled on the floor. Once it is empty and the ice removed you may discover a temperature control switch, but if not, just be prepared to repeat the exercise every 6 months or so. In any case it is not a good idea to run the freezer when it is iced up. Once it is emptied and cleared out switch it back on and wait 10 minutes before adding your stuff back. Sometimes freezers will heat up a bit before they cool down. Once you verify its getting cold, put your food back in it. Good luck.....RD
Jan 14, 2015 | Electrolux Freezers
Several times now my freezer & refrig. stopped working. Ice buildup on back of freezer wall. Especially if there is content in it. The icemaker I think was spilling water down the back (missing the...
Sounds like one or more of you defrost coils behind the back wall have gone bad...
You have to purchase the correct coil set for that model, remove the back wall, replace them and put the back cover back in place after emptying the entire contents of the freezer...
Most non HVAC people would prefer a repairman to do it.
Mar 09, 2014 | Kenmore Top Freezer Refrigerator
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 31, 2010 | Viking 42 in Built In Professional...
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
The coils are frozen solid in freezer behind back wall
frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
Jan 12, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
