Question about Amana Kitchen Ranges
Infinite Switch on Amana Stove
I'm replacing the infinite switch on our Amana stove (Model ARR6300WW). The new switch has more terminals than the old switch. I've confirmed from the supplier that I have the correct replacement switch.
I can match up all of the wires but one using the codes imprinted near the terminals. The remaining wire attaches to a terminal "P" on the old switch. But on the new switch I have 3 terminals still unused, P1, P2, and one that is unlabeled. Which is correct?
  • 59 Answers
I would start with P1. The "P" terminal is for the "element on" indicator light on the panel. Start with P1 then turn on that element and check the light for operation. P2 is most likely a loop through. Hope that helps.
Posted on Nov 02, 2008
Frigidaire glass top stove dual element ony works on high no matter were knob is set
Hello Chad;
My name is Peter. I am a retired field service appliance technician.
It sounds like you have a bad Warmer Infinite Switch.
Once installed, the switch controls your gas range's warmer drawer element. When replacing your gas range's switch, consider replacing its knob (PartsDirect part number 316442403) if it shows significant wear.
To replace your gas range's warmer infinite switch, pull the knob off the switch and remove the screws securing it. Disconnect any wires running to the switch and take note of those connections. Remove the switch and put the new one into its place, reattaching the wires to the same terminals. Be sure to unplug your gas range before beginning the repair.
25433033-yqd4wkymfcifmtxqtu0sd2am-5-0.jpg Part #: 316095500 Cost: $32.00
It is located on the right hand side of your display panel. You have to remove the side panels screws and control panel back to access.
Feb 15, 2015 | Frigidaire Kitchen Ranges
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
I have an Kenmore stove oven. It is a glass top stove that I bought in 2002. The front right element won't shut off.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Feb 05, 2011 | Kenmore Ovens
GE Stove. Model: JSP42S K5SS Problem: Left front burner is always on even turn to Off posittion. The burner indicator is on and the surface is alway hot. The stove is only 2 years old and well...
This is most certainly the infinite switch. If you pull the knob off for this eye, the shaft you see is part of that switch. You need to disconnect power to the appliance and replace it.
Nov 04, 2010 | GE JSP42 Electric Kitchen Range
Lg flat surface stove burner
Replace your infinite switch for this (your lf burner switch). Call a parts supplier with your model number, try and get an exact switch, not a generic switch. Do not replace the switch without unpluggin your range first. Good Luck, Appliance Specialists
Jan 28, 2010 | Kitchen Ranges
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Kenmore electric stove model c880.6383880 left front burner does not work....it is not the element itself as it heats up on another burner.
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Aug 19, 2008 | Stoves Kitchen Ranges
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Kitchen Ranges Logo
226 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
