Hello
This
engine and the transmission in this car are fully electronically
controlled by a computer called the PCM or TCM for the transmission,
when problems like this occur fault code or codes are set in the
PCM/TCM memory. What must be done now is to have the memory read to
retrieve this fault code. This is called a system scan, the system is
called the OBD2 electronic engine control system. Based on the
results of the fault codes you perform diagnostics and repair the
problem, that can be a sensor, wiring or even in rare cases the
PCM/TCM has failed.
