Question about HP Computers & Internet
Disc drive does not burn to disc - HP Computers & Internet
  • dcomputerman May 11, 2010
    What's your system and what's the drive and what software?
  • 275 Answers
Double click on the my computer>right click on the burner drive > properties> click on recording > enable recording
if that is already there
than go to device manager and than remove the burner from the dvd/cd rom drive option and than remove the ide channels from ide ata/atapi remove both primary and secondary both and than restart the system and than chk if the burner is working
Posted on Oct 31, 2008
Iomega Rev Disc Write Error
you might have finalised the disc on the first burn or you have not selected to burn a multisession disk
hope tis helps
Jun 07, 2012 | Iomega (32961) External REV Drive
My Ge Force will burn audio but not DVD.I have tried with Ashampoo,Record Now and Express Burner.The burning programme tells me there is no disc in drive
Hi Brian.
I think you are a little confused.
Your GeForce FX 5500 is a graphics card
All this does is allow you to see your desktop on a monitor and play some games.
For burning discs you need a cd/dvd burner. This is a cd/dvd drive that you can use to read and write cd's and dvd's
You say that your program is telling you that there is no disc in the drive. (Your CD/DVD burner drive)
You can burn audio discs so this tells me you know that much and you have blank cd's so my two things I need to tell you are these..
1. To make a DVD or Burn a DVD you need a BLANK DVD disc in your burning drive. Maybe you have mistakenly placed a CD in the drive instead?
2. Your Burner drive may not burn DVD's only CD's?
Check on the door to the drive that opens to allow you to place discs into it. It should say something like DVD multi recorder or Compact Disc re-writeable. If it does not say DVD on it anywhere your drive is not capable of burning DVD movies and therefore you will need to purchase another burner.
I hope this helps?
Sep 08, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Cant make a back up of my dvd's for the kids to use. with shrink and decripter. when i do now it says, when i play it, it says no menu.
Step 1
Be sure to erase all data on the disc, if media is rewriteable, by going up to the "Recorder" drop-down menu and clicking "Erase Rewriteable Disc." A box will pop up on which you need to choose the correct recorder from the top menu, quick or full erase (best option), and a maximum erase speed is fine.
Step 2
Choose your recorder drive on the top right drop-down menu on the main screen. The drive icon next to this menu allows you to set advanced options. (Not needed here.)
Step 3
Click on the "Burn" icon in the middle of the main toolbar. This opens up the "Burn Compilation" box.
Step 4
Click on the "Multi-session" tab on the "Burn Compilation" box. Choose "Start Multi-session disc", if the disc is to be added to later. Choose "No Multi-session disc," if the disc is to be completed with the current burn. The other options are good at the default settings.
Step 5
Click on the "Label" tab on the "Burn Compilation" box to give the disc a title that will be seen in the drives list, such as Windows Explorer, when the disc is loaded. Choose "Automatic Disc name" and enter the desired name without spaces. For spaces, add underscores (shift+hyphen).
Step 6
Click on the "Burn" tab on the "Burn Compilation" box to set desired burn and writing actions. "Determine maximum speed" lets Nero determine the recorder and disc speeds, if they are unknown. "Simulation" performs a test virtual test burn to see if all goes well. "Write," of course, burns the disc. "Finalize disc" means that the disc will be burned, so that no more can be burned on it. (For the example, check the boxes for "Write" and "Finalize disc," which is probably already checked.)
Step 7
Set "Writing speed," if known, "Writing method" as "Disc-at-once" and "Number of copies".
Step 8
Click the "Burn" button at the bottom on the "Burn Compilation" box to begin the actual burning process and the "Writing to disc" window will open.
Step 9
Check the "Verify written data" box on the bottom left of the "Writing to disc" window. This will have Nero read the disc, after it is done burning, to verify that all of the data has been properly burned to the disc. This is an important optional step, especially with really important data. If all goes well, a box will pop up stating that "Data verification completed successfully."
Step 10
Run the disc in a drive or DVD player to make sure it runs correctly. If it does, the original files on the hard drive may be deleted, if desired.
Dec 11, 2009 | Computers & Internet
Can read but can't burn dvd drive in toshiba laptop
Oct 14, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
Dvd drive will not read burned discs
The laser is weak and its not burning discs properly to begin with. Get a new drive put in there and that will take care of the problem cause a new drive will have a new laser in it.
Aug 22, 2009 | Gateway Computers & Internet
Have just downloaded Roxio 2009--have a computer purchased abour a year ago using Windows XP--has a RightScribe DVDMulti RW Disc player as E drive--never before tried to burn a disc--just tried and when...
Are you sure the DVD-R disc you are trying to use is brand new and never written on?
Try using a DVD-RW disc or a different DVD-R on this link to learn more about DVD-R DVD-RW differences and troubleshooting
Another thing is to try a different program like on the link to download it:
Jul 25, 2009 | Computers & Internet
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
Cd burner quit working properly
Just a thought! Check your hard drive is not out of space as it may be having buffering problems..
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
